10-25-2009, 12:47 AM
#1 (permalink)
best header?
What's the best header for a 04 AT? Or best bang for buck? My car has about 110k miles on it.
would a reflash be better than a header?
thanks
10-25-2009, 01:16 AM
#2 (permalink)
trancE-head
I would go reflash first.
Domo-kun co-pilot l tint l debadged l cool white (coming soon)/interior blue leds l license plate leds l Greddy evo2 exhaust l vinyl black out trim l mugen visors l mugen grille l k&n typhoon cai (installing soon)
10-25-2009, 11:49 AM
#3 (permalink)
Metal Head
both are a good start and around the same price so if you eventually plan on doing both just take your pick.
04 CGP 6spd MT
10-25-2009, 03:29 PM
#5 (permalink)
porkchop
reflash will give you the best power to dollar
  \06 tsx CGP\
10-26-2009, 01:51 AM
#6 (permalink)
My Ride: Acura TSX '05 AT
AT, don't use CT's header vibrate on AT without additional parts to mt to body. DC sucks, flexpipe often leaks.
weapon-R & Hytech (more expensive) give much nicer gain, but they run with testpipe, no cat, stinky and loud.
So, there's no 'best' header for tsx.
If you have not mod your car, get a set of UR pullies first, a must-have.
10-26-2009, 01:54 AM
#7 (permalink)
Retired
The CT header rattle is not as bad as people make it seem... it's very bearable, and often goes unnoticed.
OP - if I were to choose between the two, I'd go Hondata.
+1 on the pulleys.
parting out! http://tsxclub.com/forums/tsx-classi...-part-out.html
2005 CGP AT w/ Navi
Audio | Hertz HSK165 Components | Hertz HCX165 Coaxials | Sundown SAX 100.4 | Sundown SAZ 1500D | Two - 10" SSA Icon D1 | Mercman's Harness & Balun | Dynamat Xtreme | Dice R4 w/ Text | Optima YT D35
Suspension | Progress Rear Sway | Neuspeed Strut | Buddy Club RSD Coilovers | Ingalls Rear Camber kit | Works VS-XX Hypersilver 18x7.5 +45 // 18x8+50 | Falken FK452 | Bridgestone RE960 | MOOG Endlinks | Hawk HPS | Brembo Blanks w/ X-Drill & Slotted |
Aero/Cosmetics | | Mugen Grill | JDM Hoodtrim | 20% Tints all around | Work Extended Blue Lugs | Mugen Emblem | Euro-R Front // A-spec Rear + Side Underspoilers| Window Trim DIY Blackout | Mugen Visors | Rear window spoiler | Painted IM Cover | Yakima Ski Rack |
Lighting | 05 FishDM Headlights | EDM Taillights w/ Foglights | 4300K HID Fogs | Polarg 6000k LED 194 Corners| PIAA 7440 Mirror Orange Turns
Performance | Hondata Reflash | NST Pulleys | Modded Comptech Icebox | Comptech Header | 06 Cat/Exhaust| TB Bypass
To come... | Refinish wheel lips & Powdercoat bronze
Bay area detailin holler at me!
10-26-2009, 02:15 AM
#8 (permalink)
i have the hytech header installed on my car right now. it does use a CAT so it isn't "stinky" nor is it too loud. Only problem is that the stock exhaust wont work without modification. Its best to just get the whole hytech exhaust system.
The weapon r looks to be a solid new choice. That one has no cat (comes with test pipe), but im sure somehow you can get one to bolt up. If youre interested ask marcus at heeltoe to see if he can make you a custom FLP cat for that header... might be worth a try.
10-26-2009, 06:10 AM
#9 (permalink)
header is a header, all the same just depends on their quality of finishes. I went the cheap way and got a DC header, sounds like crap but its fine. I plan to upgrade to a J's or Toda in the future...hopefully
10-26-2009, 02:46 PM
#10 (permalink)
uhm.. I wouldn't say a header is just a header. There are different designs and sizes. It's not all about flashy looks and sounds.
10-26-2009, 02:52 PM
#11 (permalink)
February 2009 TOTM The Sleeper!
The Only Easy Day Was Yesterday"
SoCal folks need parts installed? Hit me up!!
10-26-2009, 04:18 PM
#12 (permalink)
Well all the normal 4-2-1 is the same stuff, it increase flow and that's all. But yes, whether how smooth inside the header pipes plays a factor too. Only difference I see is JDM header where their designs are different and nicer welds. Well, and obviously Hytech since its race inspired
10-26-2009, 04:24 PM
#13 (permalink)
Am I missing something? Why are recommending custom headers for an auto? Does the reflash really tune the car well enough to use that?
And random tech and magnaflow have universal cats, I even have a 16" 2.5" i/o random tech cat sitting around from my last car never installed. Not really seeing it as able to use on this 2.25 exhaust without some serious welding work.
| Thread Tools |
| Display Modes |
Linear Mode
