10-26-2009, 07:00 PM
#1 (permalink)
I am a lil confused on this K&N vs Ice box
Do I buy tyhe Ice box then install the K&N filter of is there a different K&N setup???????
I just bought a tsx (07) for a work car,,, But looking it up some.... I Drag race a 8 sec vette,, Thats my hobby,,,, But all my cars got to be nice... My TSX is pearl white Black rims with chrome lip... Blacked out lights. M3 trunk lip and blacked out grill....Thats about it... Chris......
10-26-2009, 07:08 PM
#2 (permalink)
Bork Bork Bork
K&N is an aftermarket filter. Ice box is an aftermarket Intake box. Ice box comes with its own filter but people think the K&N is better. So buy both.
10-26-2009, 07:15 PM
#3 (permalink)
My Ride: Acura TSX '05 AT
don't need the k&n filter if u get icebox. k&n filter size is designed for the stock box, and it won't fit as nicely in icebox.
10-26-2009, 09:57 PM
#4 (permalink)
it fits fine in mine. better than the foam ct filter
you can buy the icebox and use that filter its perfectly fine. some members like myself have had issues with the fitment in the box but it will work. I just installed the k & N and i deff feal more response and little more sound to it. I like it better than the ct foam filter
10-26-2009, 10:08 PM
#5 (permalink)
Bork Bork Bork
There is even a recent thread stating that the K&N fits better than the stock Icebox.
10-26-2009, 11:48 PM
#6 (permalink)
Sorry to be a Pain in the ass but b would you have the K&n Part # Thanks Chris...
10-27-2009, 12:13 AM
#7 (permalink)
Bork Bork Bork
Heh, I don't want to be mean.
But you just had to check the K&N website. Common
33-2276 - K&N Replacement Filters, Replacement Air Filter
10-27-2009, 01:19 AM
#8 (permalink)
I Do thank you much... I didnt know if it was for the factorty box.
10-27-2009, 12:21 PM
#9 (permalink)
Another option if you like to mod things yourself like I do, is this:
An even better DIY Intake!
It looks totally factory & I would bet that it as effective as the Comptech box & superior to any underhood short ram intake...
...Joe
2006 Premium White TSX, 6MT. Wifey's daily driver.
CT short shifter & aluminum shift tower bushings. M3 lip, debadged.
DIY CAI/K&N fillter. DIY exhaust (2nd resonator removed). Progress RSB.
Red "not an ashtray" painted black.  > http://tsxclub.com/forums/member-int...tsx-owner.html
10-28-2009, 01:56 AM
#10 (permalink)
I just ordered the Ice box and K&N,,, What the F#ck.. I will give it a shot.... THanks averyone for the input..
10-28-2009, 10:18 AM
#11 (permalink)
I did used the same diy parts intake just a little different then the one shown(didnt have to damage any stock parts and i made a mount for the lower tube) but i'm still running stock filter. Ive been looking into the K&N filter though
10-29-2009, 01:24 AM
#12 (permalink)
what is the point of removing the ribs in the air box? Turbulence occurs when air passes through the K&N filter. Those ribs in the air box helps to guide the air in one direction and reduce the turbulence. Without them, air will be bouncing around in the air box creating more turbulence.
10-29-2009, 11:37 AM
#13 (permalink)
The ribs, horns, passages & the huge complex intake resonator are all for noise reduction. Not for air flow.
Removing the intake resonator, smoothing the inside of the air box, should all improve air flow but I'm sure no one has flowed before and after on an air bench nor dyno'd before and after.
All I did when I modified the stock air box was to try to copy the Comptech Icebox.
Likely the real benefits are the K& N filter & the change to where the engine now draws air outside the engine compartment unlike the stock intake.
If you analyze before & after dyno's of the Comptech box or full cold air intake systems, the gains are quite small.
...Joe
10-29-2009, 12:26 PM
#14 (permalink)
reflash before i die plz
i'm just going to say that at least for my CT intake, which i purchased when it was still comptech, the K&N is not a perfect fit in the airbox lid. there is a little play around the edges, enough that unfiltered air would probably pass through vs the size of the foam filter that comes with it, and that fits perfectly.
i used weather seal to close up the sides when i used the K&N board.
| Thread Tools |
| Display Modes |
Linear Mode
