Old 10-06-2005, 11:26 PM   #1 (permalink)
My Ride: Acura tsx 2004
AzN_JuVeNiL3 is an unknown soldier, or on the road to either parallels.
Vtec controller or timer...
just wondering what this does..
AzN_JuVeNiL3 is offline   Reply With Quote
Old 10-07-2005, 12:40 AM   #2 (permalink)
i <3 my honda
My Ride: N/A
33 21.26.3.25.0 is neutral and has a clean balanced record.
lowers the vtec ingaugement
33 21.26.3.25.0 is offline   Reply With Quote
Old 10-07-2005, 12:45 AM   #3 (permalink)
code85's Avatar
My Ride: '05 Acura TSX
code85 is either technically knowledgeable, or well loved.code85 is either technically knowledgeable, or well loved.code85 is either technically knowledgeable, or well loved.code85 is either technically knowledgeable, or well loved.code85 is either technically knowledgeable, or well loved.code85 is either technically knowledgeable, or well loved.
yah i was wondering about this too..
is it a ECU ajustment or a accessory perchasable at a car store?
5AT '05 Premium White Pearl TSX
code85 is offline   Reply With Quote
Old 10-07-2005, 01:38 AM   #4 (permalink)
Staff: Rank 1
Administrator
General Operations
TOTM 2004
VTEC Controller - Allows the VTEC engagement point to be changed either lowered or raised, a piggyback device that is tapped into the OEM ECU lines. No power gains from a simple VTEC engagement point change however.
Auto Timer / Turbo Timer - Allows the engine to continue running for either a prefixed or auto-calibrated time. Used generally in high performance or turbocharged cars to allow the oil to flow/cool and the turbine to stop spinning before total power disengagement.
Old 10-07-2005, 06:28 PM   #5 (permalink)
seriouly no power gain. damn
Old 10-07-2005, 09:08 PM   #6 (permalink)
Staff: Rank 2
Chief SuperModerator
Performance
TOTM 2005
MemphisRheins's Avatar
Hondata Reflash-- 600$... Resets the factory ECU, to get some more power out of it, also lowers Vtec down to 5000 RPM's and raises your redline to 7400, some Very nice power gains
Old 10-07-2005, 09:12 PM   #7 (permalink)
TOTM 2007
Tsx536's Avatar
My Ride: Acura TSX 2004
I think memphis might have met to put that it raises the redline to 7600 rpm
K-E-N-N-Y
04 TSX CGP 5AT 265hp / 199tq
Old 10-07-2005, 09:13 PM   #8 (permalink)
Staff: Rank 2
Performance
TOTM 2005
what he said
Old 10-07-2005, 10:59 PM   #9 (permalink)
600 fo u guys --- 800 for me canadian
hahah
Old 10-08-2005, 10:26 PM   #10 (permalink)
vidgamer's Avatar
My Ride: TSX/2005
vidgamer is neutral and has a clean balanced record.
Why wouldn't there be any power gains in lowing the VTEC point? Looking at dynos, there is a bit of a dip in there. Of course, the Hondata makes a lot more sense, well, assuming there's an '05 version one day.
Seriously, the VTEC controller is such a hack, but it does (somewhat) work in general (at least it did on my previous car, which isn't a TSX). Is there something TSX-specific that prevents it from working?
vidgamer is offline   Reply With Quote
Old 10-09-2005, 04:53 PM   #11 (permalink)
Mr GenK-JomBLo
genk-jomblo's Avatar
My Ride: 04 honda accord euro
genk-jomblo is neutral and has a clean balanced record.
hahah
$1500 in oz here (someone said that).
Volk Racing GT-C 19" (8.5 + 9.5)
JP Vizage FULL Body Kit
Pics of My Car (UpDated)
Can't remember others
genk-jomblo is offline   Reply With Quote
Old 10-11-2005, 01:28 AM   #12 (permalink)
Staff: Rank 1
Administrator
General Operations
TOTM 2004
Originally Posted by vidgamer
Why wouldn't there be any power gains in lowing the VTEC point? Seriously, the VTEC controller is such a hack, but it does (somewhat) work in general.
If you only alter/modify the VTEC engagement point, there is absolutely no gains whatsoever. The VTEC engagement is triggered by the VTEC solenoid. What the controlling device does is tell it when to open.
Apart from a single on/off function, oil pressure, ignition firing settings and fuel map to match the changeover point are some of the functions triggering the power change/surge. So the gains you saw from the VTEC engagement point change will need to include the following factors to be adjusted/modified for power gains.
The Hondata reflash is an entire ECU mapping redone to suit it's new parameters of lowered VTEC engagement and higher redline. As you can see, there are more than 1 parameter to see a worthy change.
