Old 10-17-2005, 05:56 PM   #1 (permalink)
My Ride: Acura TSX 2004
BlackThorN is neutral and has a clean balanced record.
2nd gear engagement during "spirited driving"
has anyone else noticed that when you're driving fast, or really trying to accelerate that it's very difficult or damn near impossible to power shift from first to second gear
I've owned MANY cars and this is one that really seems like it does not want to power shift into second, it's almost like there is a gate that's stopping me from shifting fast
thoughts...
BlackThorN is offline   Reply With Quote
Old 10-17-2005, 06:30 PM   #2 (permalink)
Donating TSXCLUB Member
My Ride: Toyota P/U
nachob is neutral and has a clean balanced record.
It's a Feature in the TSX. The problem is that the clutch throw is very long and the drive by wire throttle is not mapped correctly. You have to make sure you have a little pressure on the throttle when upshifting. If you take your foot completely off the throttle, the car will stumble during the upshift. Keep some throttle and release the clutch a little slower. You will be able to get better. Also, you have tow depress the clutch almost to the floor especially when going from first to second.
Good luck.
nachob is offline   Reply With Quote
Old 10-18-2005, 12:32 AM   #3 (permalink)
aaron33's Avatar
My Ride: Euro CL9 K24A3 6MT
aaron33 is neutral and has a clean balanced record.
Powershift, as in flat shifting (shifting while holding WOT)?
I've shifted fast enough that the wheel still spins when I release the clutch. How fast are you trying to shift? You might be beating the triple cone synchros.
aaron33 is offline   Reply With Quote
Old 10-18-2005, 03:37 AM   #4 (permalink)
Incognito's Avatar
My Ride: Acura TSX 2005
Incognito is neutral and has a clean balanced record.
Does the TSX's 6MT have triple cone syncros for 2nd gear? If so, it "should" be fine taking a lot of abuse, including powershifting.
I too have had many MT cars, and this TSX definitely feels weird. Haven't tried powershifting it yet, but on regular quick 1-2 shifts, the car does feel pretty weak.
ABP 2005 TSX
6MT w/Navi
Daily Beater
Incognito is offline   Reply With Quote
Old 10-18-2005, 08:30 PM   #5 (permalink)
I may be beating them, but my old S2k never had this problem, it's sad...such a similar tranny feel and yet so far away
Old 10-19-2005, 08:21 AM   #6 (permalink)
aaron33's Avatar
Triple cones make the shift smooth, but as a result, you can shift faster than the synchros can speed up your 2nd gear. The S2k should have a higher spec gearbox that can tolerate more abuse in order to be a proper roadster.
Old 11-12-2005, 03:10 AM   #7 (permalink)
peter_earthpig
Guest
Posts: n/a
Good luck.
That's exactly right, you have to stay in the throttle some to get the 1-2 shift quickly and you're better off not popping the clutch as much as it causes the DBW to stumble. It's not hard to shift the TSX quickly, just takes fiddling.
Old 11-12-2005, 04:53 PM   #8 (permalink)
Loc
My Ride: Toyota Camry 97
Loc is neutral and has a clean balanced record.
Can you tell a n00b what powershifting is?
Loc is offline   Reply With Quote
Old 11-14-2005, 12:17 AM   #9 (permalink)
usually powershifting is shifting either without taking your foot off the gas at all or at least leaving it on partially and just slamming the car into the next gear and using no clutch, although sometimes you have to fiddle with it a little to get it right
usually from 1-2 or 3-4, straight down and hammering it into gear
its' somewhat difficult in new cars with synchro's but if you ever drive a dogbox race trans it's TONS of fun
Past Cars
93 BMW 325is Mild Mods
98 Integra 4 door many mods
2000 Honda S2k
02 Mercedes C32 AMG
Current Car:
2004 TSX MT Nav
Full Body Kit, No Spoiler
Comptech SSK
Tint, AEM SRI Intake, DC Sports Header
Hondata IM Gasket, Oil Seperator
Old 11-14-2005, 07:11 AM   #10 (permalink)
Loc
^^ does this damage any parts or put extra wear?
Old 11-14-2005, 10:56 AM   #11 (permalink)
My Ride: Toyota P/U
Damn straight it does..if you miss the shift. You are sliding on the synchros. If you get it just right the wear is minimal but if you miss, and it's easy to do so, you can kill synchros and eventually gears. I don't know what the point of it is myself. a million years of combined engineering education have put clutches in every manual in the world but a few guys somehow know better than all the PhDs in the automotive world. Not to mention, Hurley Haywood, Rod Millen, Fangio, Shumacher, Senna, Gordon and every other guy that races uses the clutch if it's available? I just don't know sometimes.
