Old 11-04-2005, 05:58 PM   #1 (permalink)
My Ride: honda/tsx/04
advan048 is neutral and has a clean balanced record.
Help!! defi vsd concept install
hi there, i'm trying to install the defi vsd concept to my 04tsx, but i can't find the speed wire from ecu, can u guys help me out!!thanks!!
advan048 is offline   Reply With Quote
Old 11-04-2005, 06:08 PM   #2 (permalink)
2005 TSX 6MT Nav
spyguy's Avatar
My Ride: 2005 TSX 6MT Nav
spyguy has a slight shameless behaviour in his/her past.
what does this VSD concept display exactly?
2005 NBP 6MT w/Nav Ebny interior
-injen CAI
-Comptech short shifter
-Skunk2 shift knob
-Tein Super Street coilovers
-Ingall rear camber kit
-A-SPEC body kit
-progress rear sway
-Comptech front strut
-powerslot rotors
-hawk HPS pads
spyguy is offline   Reply With Quote
Old 11-04-2005, 06:31 PM   #3 (permalink)
Staff: Rank 1
Administrator
Technical & Staff Operations
Peregrine's Avatar
My Ride: '04 TSX - SSM
Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.
I can tell you where the tach signal wire on 04 TSX is
Peregrine is offline   Reply With Quote
Old 11-04-2005, 06:51 PM   #4 (permalink)
Donating TSXCLUB Member
dontcare4urshyt's Avatar
My Ride: Acura/TSX/2005
dontcare4urshyt is neutral and has a clean balanced record.
umm is the gauge cluster too far?
my car has more miles than yours!!
dontcare4urshyt is offline   Reply With Quote
Old 11-05-2005, 01:01 PM   #5 (permalink)
yes, the gauge cluster is too far, and i look at the serive manual that suppose have this wire in ecu, but when i check my ecu it's empty in that spot..
Old 11-05-2005, 11:40 PM   #6 (permalink)
TOTM 2006
JeffTSX's Avatar
My Ride: 04 Pearl White TSX 6spd
JeffTSX is neutral and has a clean balanced record.
Okay can you tell me then? Cause I've flipped through the service manaul and I can't seem to find the "wire" but I can only locate the "cluster unit". I've been trying to install a Stwert Warner shift light for a while now.
That's some good sh*t!!!
JeffTSX is offline   Reply With Quote
Old 11-07-2005, 01:11 AM   #7 (permalink)
Staff: Rank 1
Administrator
Peregrine's Avatar
The Tachometer wire is BLUE (AC) at ECM/PCM located on front of the transmission tunnel (close to the firewall). The connectors are on passenger side. The tach wire is in the white 31 pin connector E, pin 25.
I can vouch for that because I used that location myself. It's kind of hard to get to. I had to move the carpet away from the area, then dig to find that connector, disconnect it, find the wire and then solder into it (I tested it while it was connected, of course), then I could plug it back in. If you're going to use a wire connector instead of soldering, you may not need to unplug it.
I also have some info on the Speed sense wire, but this I never tested:
BLUE/WHITE (AC) at PCM module in front of center console under dash.
Good luck
Old 11-07-2005, 08:18 AM   #8 (permalink)
yf1
yf1's Avatar
My Ride: Accord Euro 2004
yf1 is neutral and has a clean balanced record.
Now I can't vouch this is definately the write pin outs for the TSX - this is the diagram I used for the APEXI RSM on the K2 4 Accord Euro CL9 in Australia.
http://www.ozhonda.com/forum/showthr...exi+rsm+wiring
Euro 6mt / Prodrive 17" GCO7C / Dunlop 235 3000As / Rays and McGuard lock nuts / Comptech Icebox / ITG Racing filter / Whiteline Sway Bar / Cusco Strut Brace / DC5R shifter / Apexi RSM / Honda A-SPEC suspension / Euro R Body Kit
yf1 is offline   Reply With Quote
Old 11-07-2005, 09:24 AM   #9 (permalink)
Staff: Rank 1
Administrator
Peregrine's Avatar
All right, so from this ECU diagram for CL9 it looks like the speed wire is in pin 26 of the same 31 pin connector as the tach wire.
