Did you buy your TSX brand new? If so, and if following the recommended break-in procedure, you probably won't feel VTEC until after the 600 mile break in period, in which case you'll feel it at around 6000 RPM. Just a thought, but you might not want to install the Injen until after the 600 mile break-in. The TSX has a K24A2 engine in it, and it is a bit different from the K20's. I believe the TSX is significantly heavier than the RSXs though.
