Originally Posted by sjlee
You'll most likely hurt your engine before you hurt your transmission when downshifting improperly. The biggest risk with downshifting is downshifting when your RPMs are too high. This will lead to bent valves rather than damage to your transmission. This only applies to those with MT. If you have an AT, you will not be able to downshift if your RPMs are too high.
If you downshift properly, you won't hurt your transmission any more than when downshifting when accelerating. You will definitely save your brakes, however.
Neutral drops will definitely hurt a transmission.
From what SJ is saying, it sounds like if you have the AT, there's no downside whatsoever in using the downshift on the SS to save the brakes.
Indeed all you'll do is.......save the brakes.
Of course most of the time we'd rather just BRAKE, but that's another story.
