12-07-2005, 06:10 PM
#1 (permalink)
Understanding What "CL7", "CL8" & "CL9" Means
This is perhaps the most frequent question asked. Each abbreviation is used by Honda/Acura and aftermarket manufacturers to determine which model in compatibility of parts or components in general.
Chassis Code - ABA-CL7 | JDM Accord Euro R
Transmission - 6 Speed Manual Only | FF
Factory Length, Width & Height - 4.665M, 1.760M & 1.450M
Weight - 1,390KG
Engine Type - K20a DOHC i-VTEC 1,998CM³
Compression Ratio - 11.5
Fuel Tank Capacity - 65L
Max Horsepower - 162kW [220PS] @ 8,000RPMs
Max Torque - 206Nm [21.0KG/m] @ 6,000RPMs
Tyres - 215/45R17 87W
Chassis Code - DBA-CL7 | JDM Grade 20EL/20A
Transmission - 5 Speed Automatic & 6 Speed Manual | FF
20EL Grade Weight - 1,400KG | 1,410KG (S SRS) | 1,420KG (S SRS + Sunroof)
20A Grade Weight - 1,370KG | 1,380KG (S SRS) | 1,390KG (S SRS + Sunroof)
Compression Ratio - 9.8
Max Horsepower - 114kW [155PS] @ 6,000RPMs
Max Torque - 188Nm [19.2KG/m] @ 4,500RPMs
20EL Grade Tyres - 195/65R15 91H | Factory Option 205/55R16 89V
20A Grade Tyres - 195/65R15 91H
Chassis Code - ABA-CL8 | JDM Grade 20EL/20A
Transmission - 5 Speed Automatic & 6 Speed Manual | 4WD
Factory Length, Width & Height - 4.665M, 1.760M & 1.470M
20EL Grade Weight - 1,470KG | 1,480KG (S SRS) | 1,490KG (S SRS + Sunroof)
20A Grade Weight - 1,450KG | 1,460KG (S SRS) | 1,470KG (S SRS + Sunroof)
Fuel Tank Capacity - 60L
Max Horsepower - 112kW [152PS] @ 6,000RPMs
Max Torque - 186Nm [19.0KG/m] @ 4,500RPMs
Chassis Code - ABA-CL9 | Worldwide Grade
Weight - 1,440+10KG | 1,450+10KG (S SRS) | 1,460+10KG (S SRS + Sunroof)
Engine Type - K24a DOHC i-VTEC 2,354CM³
Compression Ratio - 10.5
Max Horsepower - 147kW [200PS] @ 6,800RPMs
Max Torque - 232Nm [23.7KG/m] @ 4,500RPMs
Tyres - 205/55R16 89V | Factory Option 225/45R17 90W
12-14-2005, 03:37 AM
#2 (permalink)
My Ride: Honda / Accord-Euro / 2005
What about JHM-CL7, as my Euro Accord has?
2006 Alabaster Silver Metallic Euro Accord 2.0i
12-16-2005, 01:34 AM
#3 (permalink)
JHM means Japan Honda Manufactured which is stamped on all export Honda cars manufactured in Japan and exported overseas, while your grade will be DBA-CL7 | JDM Grade 20EL/20A if you don't own an Euro R.
12-16-2005, 03:26 AM
#4 (permalink)
Thanks for clearing it
Where can you see the DBA string? I understood from your post that it should be in the chassis code, however I do not find it there.
Does this mean that, for example, an Euro Accord owner can claim that it's a JDM Accord, or are there any differences between the 2?
Thanks again, great info there
12-18-2005, 11:36 PM
#5 (permalink)
DBA & ABA classification is not stamped on your chassis plate, it's a Honda category code only.
JDM or export grade, the only difference is what type of hardware and power output it's running.
03-14-2006, 01:00 PM
#6 (permalink)
what would be a 2006 Acura TSX 6-MT with Navigation purchased in America?
03-14-2006, 09:24 PM
#7 (permalink)
04-18-2006, 04:40 PM
#8 (permalink)
how about 2006 tsx 5at no navi purchased in america
04-19-2006, 04:43 AM
#9 (permalink)
09-02-2006, 05:46 PM
#10 (permalink)
on leave back to modding
My Ride: acura tsx 2006 dpg
2006 5at w/ nav?
2006 TSX a/t w/ navi
09-03-2006, 10:20 PM
#11 (permalink)
10-06-2006, 04:03 PM
#12 (permalink)
all the 2006 use a 2.4L engine, so all 2006 TSX are CL9.
06 NBP TSX with Navi
03 IBP IS300
10-25-2006, 09:21 PM
#13 (permalink)
My Ride: BMW/X3 3.0si/2008
The 2.4 exists since 2004...
I sure like the specs of that CL7...
BMW X3 3.0si with luxury package since Jan. 8, 2008
The X3 is great, but my TSX (2004 SSM/ebony 6 MT) was one great ride!
11-02-2006, 12:23 AM
#14 (permalink)
2005 5at?
"The darker the world gets the more optimistic I become." - Ben Harper
01-13-2007, 04:11 AM
#15 (permalink)
On and Off Member
Originally Posted by AtlTSX90
2005 5at?
TSX 2004-2007 AT/MT Nav or No Nav are all CL9.
| Thread Tools |
| Display Modes |
Linear Mode
