Old 03-17-2006, 11:59 AM   #1 (permalink)
My Ride: Acura TSX 2006
Supamanluva is neutral and has a clean balanced record.
Bluetooth feature
Any of you '06 guys had problems with your Bluetooth connection?
I have a Sprint phone (Treo) and on three different occasions, my car says it can't pick up the phone. I checked the signal and that was ok, so I re-paired it to my car and then it worked fine. Has this happened to anyone? Hopefully it's the phone and not the car.
Supamanluva is offline   Reply With Quote
Old 03-17-2006, 07:42 PM   #2 (permalink)
'06 CGP w/Nav
Sojournin's Avatar
My Ride: Acura TSX/2006/CGP
Sojournin has a slight shameless behaviour in his/her past.
I have a Verizon Razr. No problems. Have you tried pairing your Treo to another blue tooth device (i.e. ear piece) and had any problems?
Sojournin is offline   Reply With Quote
Old 03-18-2006, 01:26 AM   #3 (permalink)
My Ride: Looking for TSX
j1ggastyle is neutral and has a clean balanced record.
This was happening to me too, unit I found out that it was a memory issue. Trying moving your files and pictures from the phone to your memory card.
j1ggastyle is offline   Reply With Quote
Old 03-19-2006, 04:04 PM   #4 (permalink)
JT2k4TSX
My Ride: 2004 Acura TSX
JT2k4TSX is neutral and has a clean balanced record.
Hey guys I know this is a stupid question but do all 04's come with the bluetooth feature?? This is my 2nd 04 and I didnt even think we had that feature.
JT2k4TSX is offline   Reply With Quote
Old 03-19-2006, 11:27 PM   #5 (permalink)
Smoothie97's Avatar
My Ride: Acura/TSX/2005
Smoothie97 is neutral and has a clean balanced record.
04 and 05 do not have bluetooth built-in. Only the 06 has bluetooth.
Smoothie97 is offline   Reply With Quote
Old 03-20-2006, 01:15 PM   #6 (permalink)
Likes Navi
My Ride: 2004 Acura TSX w/Navi
RyanDe680 is neutral and has a clean balanced record.
I wish
2004 Carbon Grey TSX/ Navi
I am teh Ryan
http://www.chicagoturmoil.com - Chicago's new home for anything.
RyanDe680 is offline   Reply With Quote
Old 03-20-2006, 04:17 PM   #7 (permalink)
My Ride: 2006 tsx
kosta is neutral and has a clean balanced record.
i dont have this problem but i have another one
my phone will always display a lower battery level when connected
if i get out of the car, turn the phone off and on, the battery level goes up
kosta is offline   Reply With Quote
Old 03-25-2006, 08:54 PM   #8 (permalink)
RoamingSnake
Guest
Posts: n/a
Well....the bluetooth feature does uses a lil' more battery than usual. That's probably why you are seeing more battery consumption than usual. When you power off the phone, it is natural to see the battery meter being somewhat off when you power the phone right back up. Your issue may be normal, but then again it could also be that your battery's is dying...
Hopefully this helps...
Old 03-30-2006, 12:23 AM   #9 (permalink)
My Ride: 2006 TSX 6Sp
craddie is neutral and has a clean balanced record.
No problems here - although my Nokia 6620 won't broadcast any info other than CallerID. I don't get signal, battery or roaming indicators. Guess my next phone will have to be from the "approved list". :/
craddie is offline   Reply With Quote
