I'm not following.
I'm quite sure the VSA has nothing to do with the TPMS.
VSA operation or function should not change if you install wheels with no TPMS sensors.
You're over-thinking the TPMS system. Temporarily install your spare (which has no TPMS sensor) on the rear of your car & test things out.
You'll see how the TPMS reacts & how the VSA reacts.
..Joe
2006 Premium White TSX, 6MT. Wifey's daily driver.
CT short shifter & aluminum shift tower bushings. M3 lip, debadged.
DIY CAI/K&N fillter. DIY exhaust (2nd resonator removed). Progress RSB.
Red "not an ashtray" painted black.  > http://tsxclub.com/forums/member-int...tsx-owner.html
