Old 10-13-2009, 08:14 AM   #1 (permalink)
My Ride: tsx/2006/Grey
bugeyes is an unknown soldier, or on the road to either parallels.
Best way to get access to ATF drain plug
I was trying to change the ATF myself but found it is so difficult to get access to the drain plug, what is the correct way to get to it? thanks. It is '06 AT transmission.
bugeyes is offline   Reply With Quote
Old 10-13-2009, 08:48 AM   #2 (permalink)
My Ride: tsx/04/black
NTSX is neutral and has a clean balanced record.
Go to a dealershipp ..it's not that pricey... i work @ a honda dealership....=P
NTSX is offline   Reply With Quote
Old 10-13-2009, 02:32 PM   #3 (permalink)
Staff: Rank 5
Moderator
Marketplace
Pacemaker_Guy's Avatar
My Ride: 05 Auto ABP
Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.Pacemaker_Guy is either reputation whoring, or truly reaching the elite club.
1/4 socket is all you need. Their is a panel on the bottom you take off (the larger plastic undertray). Someone made a DIY a while ago this year about doing it. It's super easy but remember to use Acura ATF nothing else.
Palm Beach Hot Rods
Speed-Theory 973-227-2119
^Honda shop in Fairfield NJ
Pacemaker_Guy is offline   Reply With Quote
Old 10-13-2009, 02:36 PM   #4 (permalink)
My Ride: 2005
saveth is an unknown soldier, or on the road to either parallels.
You mean 3/8's
the only tools I used was a 10mm socket, a flat head screw driver,3/8's rachet and maybe a Phillips screwdriver.
saveth is offline   Reply With Quote
Old 10-14-2009, 12:22 AM   #5 (permalink)
Staff: Rank 5
Moderator
Marketplace
yes, sorry 3/8 is correct
Palm Beach Hot Rods
Old 10-14-2009, 08:30 AM   #6 (permalink)
NTSX, my dealer wants $200 for it!!!!!!!!!!!!!
Old 10-14-2009, 12:39 PM   #7 (permalink)
Staff: Rank 6
Petty Moderator
Performance
endlesswinterco's Avatar
My Ride: 06 ABP AT
endlesswinterco is on the distinguished road to high status recognition.endlesswinterco is on the distinguished road to high status recognition.endlesswinterco is on the distinguished road to high status recognition.endlesswinterco is on the distinguished road to high status recognition.endlesswinterco is on the distinguished road to high status recognition.endlesswinterco is on the distinguished road to high status recognition.endlesswinterco is on the distinguished road to high status recognition.
i payed $140 about a month and half ago at my stealer. didn't feel like doing it myself. i guess you gotta pay to be lazy! haha
endlesswinterco is offline   Reply With Quote
Old 10-14-2009, 01:43 PM   #8 (permalink)
KBH
My Ride: TSX 2004
KBH is an unknown soldier, or on the road to either parallels.
It's helpful to jack up the car for the first drain since you need to remove or at least bend back the splash shield to get access to the drain bolt. That bolt is also on pretty tight from the factory so you need the room to get enough leverage on it. You can do the subsequent drains with the car on the ground. You can go for Honda brand Z1 ATF. It might be a few quarters cheaper than the Acura parts counter. you need to do 4x drain/fill to change >90% of the fluid. Consider changing your ATF filter as well
KBH is offline   Reply With Quote
Old 10-14-2009, 05:07 PM   #9 (permalink)
Who doesn't love a Honda!
TPhong's Avatar
My Ride: '05 SSM Acura TSX/'00 GPW S2000 AP1
TPhong , with enough acceptance, will soon become famous.TPhong , with enough acceptance, will soon become famous.TPhong , with enough acceptance, will soon become famous.
How many quarts of Honda Z1 ATF will I need to fill it back up?
TPhong is offline   Reply With Quote
Old 10-14-2009, 08:51 PM   #10 (permalink)
KBH
My Ride: TSX 2004
Each drain will be about 3 quarts so buy a case of 12 bottles to do it well. See this thread
How to change your Acura TSX Automatic Transmission Fluid
Old 10-14-2009, 09:07 PM   #11 (permalink)
My Ride: Acura/TSX/2005
HNDFRK is an unknown soldier, or on the road to either parallels.
That is probably an AT Flush which Honda does not recommend on their transmissions.
The actual recommended process consists of changing the fluid a couple of times (~3) and driving the car in a predetermined way in order to recycle most of the tranny fluid, this should be done at aprox. 60K miles.
Now some dealers just do a single drain and refill at 15k intervals, this seems to work fine in my car. My dealer only charges $35 for the drain and refill.
HNDFRK is offline   Reply With Quote
Old 10-15-2009, 01:08 AM   #12 (permalink)
My Ride: TSX/2006/Grey
bunta is an unknown soldier, or on the road to either parallels.
I did the tranny fluid swap today. Yea, you gotta take the entire cover off. I broke a few of the clips while taking it out, the clips are 3 dollars a pop at the dealership. The drain bolt is a pain to take out, take alot of force. The picture below shows the location of the drain bolt.
bunta is offline   Reply With Quote
Old 10-15-2009, 11:42 PM   #13 (permalink)
USMC
newapocalypse's Avatar
My Ride: TSX / 2004 / Gray
newapocalypse , with enough acceptance, will soon become famous.newapocalypse , with enough acceptance, will soon become famous.
Yay me on making that DIY :-)!!!
Don't feel bad took me years to find the drain plug too....
edit: You definitely only need 5 quarts tops to do your first flush. You have to remember not all of the atf comes out when you do the flush... and Acura ATf and Honda ATF-z1 = same thing so go nuts...
Last edited by newapocalypse; 10-15-2009 at 11:44 PM. Reason: addition Reason: addition
newapocalypse is offline   Reply With Quote
Old 10-16-2009, 10:01 AM   #14 (permalink)
My Ride: TSX/08/CGP
Racecarbox616 is an unknown soldier, or on the road to either parallels.
Originally Posted by bunta View Post
Where do you have that jack stand supporting the car at?
Racecarbox616 is offline   Reply With Quote
Old 10-16-2009, 11:12 PM   #15 (permalink)
By the way, that's not my car. Looks like the person placed the jackstand on the suspension. I place the jack stands on the flange along the side of the car.
