Old 10-22-2009, 07:52 PM   #1 (permalink)
My Ride: 04' Milano Red TSX
Hoover2880 is an unknown soldier, or on the road to either parallels.
Coolant and Tranny Fluid
I'm planning on flushing my radiator and putting new coolant/amti freexe in but I'm curious as to what sbest. What are most people running on here? I know some coolants have certain chemical additives that eat through the ceramic seals on water pumps and I don't wanna use something that will cause that.
Also has anyone drained and changed their tranny fluid. If so with what did you replace it with.
Hoover2880 is offline   Reply With Quote
Old 10-22-2009, 08:38 PM   #2 (permalink)
My Ride: 04 acura tsx
speedlimitz , with enough acceptance, will soon become famous.speedlimitz , with enough acceptance, will soon become famous.
I've done both. Coolant I went with the Honda blue coolant and for my manual trans I've always used Honda fluid
speedlimitz is offline   Reply With Quote
Old 10-22-2009, 09:18 PM   #3 (permalink)
EuroRspec's Avatar
My Ride: S2000
Honda fluids only.
Exterior-Stock
Interior-Stock
Engine-Stock
Old 10-23-2009, 11:26 PM   #4 (permalink)
I'm assuming I can pick these up at the dealer ship
And what oils are you using? I use mobil 1 synthetic and it sems to be fine
Old 10-24-2009, 10:32 AM   #5 (permalink)
My Ride: cl7/2003/milano red
slammedmind is an unknown soldier, or on the road to either parallels.
engine: motul 300v fully synthetic 5w30
tranny: Redline Mtl gear oil
Coolant: Redline water wetter with honda blue coolant.
slammedmind is offline   Reply With Quote
Old 10-25-2009, 11:46 AM   #6 (permalink)
Metal Head
1TSXer's Avatar
I use Royal Purple 5w30 oil w/a K&N oil filter in the engine, Amsoil Syncromesh in the transmission and OEM Honda Radiator fluid w/Redline water wetter.
04 CGP 6spd MT
