Old 10-26-2009, 05:58 AM   #1 (permalink)
mjsparky363
My Ride: Acura TSX 2005
mjsparky363 is neutral and has a clean balanced record.
5w/20-5w/30
I did a search with not much luck so, anyone using 5/20 full syn. motor oil instead of 5/30? Any downsides to using the lighter weight ? My reason is I can get 5/20 for about 1/2 price ( my truck and volvo and suv use 5/20) from a friend.
mjsparky363 is offline   Reply With Quote
Old 10-26-2009, 07:45 AM   #2 (permalink)
USMC
newapocalypse's Avatar
My Ride: TSX / 2004 / Gray
newapocalypse is neutral and has a clean balanced record.
Personally i dont think there is much of a difference, specially seeing some of the newer honda vehicles all use 5w-20 since its supposed to help with gas mileage. I wouldnt do it, you save 10 bucks every 5-10 k miles, whoopiiiieee.... total savings... maybe 100-150 (assuming you keep ur car for a while) Replacing your engine .... 4k plus
newapocalypse is offline   Reply With Quote
Old 10-26-2009, 02:13 PM   #3 (permalink)
EuroRspec's Avatar
My Ride: 96 Accord
EuroRspec is on the distinguished road to high status recognition.EuroRspec is on the distinguished road to high status recognition.EuroRspec is on the distinguished road to high status recognition.EuroRspec is on the distinguished road to high status recognition.EuroRspec is on the distinguished road to high status recognition.EuroRspec is on the distinguished road to high status recognition.EuroRspec is on the distinguished road to high status recognition.
You should be perfectly fine since 5w is for 5 winter, the higher number is for summer.
Old 10-27-2009, 10:28 PM   #4 (permalink)
500K Poster! - Premium Club Member
ShzaTSX's Avatar
My Ride: '04 TSX
ShzaTSX , with enough acceptance, will soon become famous.ShzaTSX , with enough acceptance, will soon become famous.ShzaTSX , with enough acceptance, will soon become famous.
I believe they actually changed factory oil spec for tsx to 5w-20. If you get it done at a dealership it should be.
I throw in 0w-30 synthetic for the same reason, I find it cheaper.
Either way, won't be an issue.
Owner of the 500,000th post!! ^_^
-'04 CGP Navi 6-speed
-Injen CAI
-Buddy Club N+, Oil/Thermostat Cap!
-Ingalls camber
-JDP CF lip
"To give anything less than your best, is to sacrifice the gift."
ShzaTSX is offline   Reply With Quote
Old 10-28-2009, 12:20 AM   #5 (permalink)
What to put here...
My Ride: 2004 PWP on Ebony TSX 6MT Non-Navi
curls , with enough acceptance, will soon become famous.curls , with enough acceptance, will soon become famous.
Actually that is incorrect. Most oils these days are multi-weight oils (hence the 2 numbers, such as 5w-30).
From HowStuffWorks "Measuring Motor Oil Viscosity"
"Multi-weight oils (such as 10W-30) are a new invention made possible by adding polymers to oil. The polymers allow the oil to have different weights at different temperatures. The first number indicates the viscosity of the oil at a cold temperature, while the second number indicates the viscosity at operating temperature."
So, at non-operating temperature, such as starting your engine in the morning, the oil is very thin (first number weight) so that it can reach the tiny places in the engine that need it most -- between bearings and crankshaft, between valves and cam lobes, and between the pistons and the cylinder walls. But at a higher temperature, such as when the car is warmed up and driving, this thin of an oil would not protect the engine at all, so the addition of polymers and the addition of heat (from combustion), causes the oil to thicken up to the 2nd number weight.
Ideally you'd want a very low first number (0w or 5w) to protect on startup, and a higher but not prohibitively high 2nd number (20 for some cars and CAFE (fuel economy) requirements, 30 for most cars, and 40 or higher for higher-heat applications such as a turbo).
The TSX specs 5w-30 for the K24 and that is what you should run. However, any xw-30 should be fine as long as its a good quality oil. I used to run a 0w-30 Esso full synthetic group IV oil that was stellar, but its hard to find and I now use Pennzoil Platinum 5w-30 which tests as good or better than Mobil1, for about 1/2 - 2/3 of the price.
2004 TSX, PWP on Ebony, 6MT, #00032. 2006 short block put in at 92,000km --> warranties are a good thing!.
Tein, Tokico, DC Sports, Injen, Unorthodox Racing, Comptech, Powerstop, Ingalls ETD.
curls is offline   Reply With Quote
Old 10-28-2009, 01:38 AM   #6 (permalink)
My Ride: tsx 2005 nighthawk black pearl
tsxklap is neutral and has a clean balanced record.
curls, i love you!!!!! (in a non homosexual way, of course) brilliant and right on as always
-deadlyklappy87 from azine
-05 NBP auto, 20% tint, Memphis subs, Kicker amp
ENGINE: -Hondata reflash, AEM SRI
EXHAUST:-CT header, CT catback, RT high flow cat
SUSPENSION: ASPEC, CT rsb
BRAKES:-Racingbrake UP slotted rotors, Hawk HPS pads, Racingbrake SS lines, gold calipers
INTERIOR: -Acura racing pedals, blue/white LED lights, Passport 8500 X50
tsxklap is online now   Reply With Quote
Old 10-28-2009, 03:22 AM   #7 (permalink)
EuroRspec's Avatar
My Ride: 96 Accord
Yes I already know. It doesn't say anything different from what I said.
Old 10-28-2009, 12:58 PM   #8 (permalink)
What to put here...
Actually the way I interpreted your statement was that the first number was the winter weight, and the 2nd number was the summer weight. We both (?) know that is incorrect as the numbers have nothing to do with the season and everything to do with the engine temperature.
Old 10-28-2009, 01:18 PM   #9 (permalink)
My Ride: TSX/2006/White
CalgaryTSX has a spectacular aura and a relevant respect from many.CalgaryTSX has a spectacular aura and a relevant respect from many.CalgaryTSX has a spectacular aura and a relevant respect from many.
You guys are saying the same thing!
In theory 5W/30 is the same as straight 30 at hot temperatures but in reality it doesn't work that way.
Multi-grade oils are a compromise.
While the trend today is to run as thin as oil as possible to get another miniscule amount of mpg & hp, how does this really thin oil affect engine protection & longevity?
Especially in a high revving 4 cylinder engine?
In addition, today's modern "catalytic & environment friendly" engine oils are worse than ever.
I prefer thicker oils in my engines in the summer, running 10W-40 in our TSX and my 5.0L Mustang & 10W-30 in the TSX in the winter.
...Joe
2006 Premium White TSX, 6MT. Wifey's daily driver.
CT short shifter & aluminum shift tower bushings. M3 lip, debadged.
DIY CAI/K&N filter. DIY exhaust (2nd resonator removed). Progress RSB.
CalgaryTSX is offline   Reply With Quote
Old 10-28-2009, 02:30 PM   #10 (permalink)
我々は火事を起こしませんでした
harmonichonda's Avatar
My Ride: '04 Blue TSX || '10 Black Accord
harmonichonda is either technically knowledgeable, or well loved.harmonichonda is either technically knowledgeable, or well loved.harmonichonda is either technically knowledgeable, or well loved.harmonichonda is either technically knowledgeable, or well loved.harmonichonda is either technically knowledgeable, or well loved.harmonichonda is either technically knowledgeable, or well loved.
I love how oil definitions always spark some epeen controversy on forums..
Though personally I use 0w 30 amsoil year round unless torco has a sale in which case I get their 5w30+zinc
harmonichonda is offline   Reply With Quote
