Old 09-19-2004, 02:20 PM   #61 (permalink)
johnej's Avatar
My Ride: acura tsx 2004
johnej is neutral and has a clean balanced record.
Is that a non navi unit or a navi unit larch..
"Daring you to figure out what the j stands for"
johnej is offline   Reply With Quote
Old 09-19-2004, 02:21 PM   #62 (permalink)
(9)
Ex-Moderator Emeritus
larchmont's Avatar
My Ride: TSX '04 CG/Ebony 5AT Nav
larchmont is neutral and has a clean balanced record.
Nav -- but I don't think it matters.
Not 100% sure, but I think the problem has been happening in either kind.
Wouldn't be too hard to check out. I'll prolly do it later.
larchmont is offline   Reply With Quote
Old 10-01-2004, 10:43 PM   #63 (permalink)
Non-Registered User
Cyde's Avatar
My Ride: TSX 2004 Duh!
Cyde is neutral and has a clean balanced record.
yeah my center console went out for no reason, and i tried my method, and it worked.. but if it dosen't then you got a more serious problem =(
The problem people have is center console controls light going out but not the clock. If your clock and the entire center console out too, then you just have it disabled, and you can fix that by re-enabling by holding the cd/aux button down.
The message posted is intended only for the designated recipient(s), person or entity to which it is addressed and may contain confidential, privileged, proprietary, and/or otherwise private information. Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon, this material by persons or entities other than the intended recipient(s) is prohibited. If you received this in error, please contact the sender and delete the material from any computer.
Cyde is offline   Reply With Quote
Old 01-03-2005, 11:36 PM   #64 (permalink)
CivicBackwardStillCivic
Curse of Anubis's Avatar
My Ride: acura/tsx/2004
Curse of Anubis is neutral and has a clean balanced record.
My center console just went out yesterday, i droped by Acura in Riverside, they ordered the parts and told me about 7 days....
Lets see how my story would go... from here...
Curse of Anubis is offline   Reply With Quote
Old 01-04-2005, 01:23 AM   #65 (permalink)
(9)
larchmont's Avatar
Good luck -- hope it goes smoothly.
BTW....when did you get the car? I'm curious because I'm wondering if the newer TSX's are still having the problem. It had seemed that maybe the problem was most prevalent in the early ones, then maybe Honda/Acura worked out the bugs.
Old 01-07-2005, 03:02 PM   #66 (permalink)
My Ride: 2006 RL
miner is neutral and has a clean balanced record.
My '04 TSX has a build number of 370 and has 33XXX miles on it. I have yet to expereince the center stack light problem. Thank goodness.
2006 RL NBP/Parchment
2008 TSX Milano Red/Parchment Navi 6MT
1999 Prelude
miner is offline   Reply With Quote
Old 01-07-2005, 03:28 PM   #67 (permalink)
(9)
larchmont's Avatar
Wow -- one of the real originals!
BTW what about rattles? We've had the impression also that those were most common in the earlier ones......
Old 01-08-2005, 11:32 AM   #68 (permalink)
oo7bondgrrl's Avatar
My Ride: Acura/TSX/2004
oo7bondgrrl is neutral and has a clean balanced record.
i have the rattles *and* my console lights went out a freakin long time ago. i have all of the buttons memorized, but i'm probably going to get it fixed soon because it's stupid. my build number is 11,35xx. i probably had 15,000 miles when the lights went out.
04tsx.cg.quartz.at.nonnavi
x debadged
x acura oem body kit
x 20% tint all around
x eibach pro kit
x 19x8 hyperblack dl-46/ssr-gt3
x 225/35/19 toyo fz4 tires
x mugen grill
x full led conversion
x ebony oem floormats
x tsx led replacement guide
x cardomain.com
boooooo... whore. - regina george, mean girls
oo7bondgrrl is offline   Reply With Quote
Old 01-08-2005, 12:02 PM   #69 (permalink)
My Ride: 2006 RL
My only rattle is a now-&-then click from around the windshield molding. I have had my doors dynamatted so no problem there. I had a rattle from the glove box (dash area) but I fixed that by putting the stickable rubber feet used for lamps/etc. on the door edge to make it a tighter fit. No more problem.
1999 Prelude
Old 01-19-2005, 08:53 PM   #70 (permalink)
gasha1
Guest
Posts: n/a
Same Problem Dealer Replaced Under Warrentty No Drama
Old 01-19-2005, 10:15 PM   #71 (permalink)
johnej's Avatar
welcome gasha1
Old 01-30-2005, 12:56 PM   #72 (permalink)
My Ride: 2004 White TSX
Ashyne is neutral and has a clean balanced record.
Hello,
Just wanted to add my input with regards to this issue. The lights on my "centre console" went out last week and I was planning on bringing my car in already to replace the windshield anyways. When I dropped the car off I told them about the interior lights and they said they would look at it.
They kept my car for 2 days and replaced the windshield and the entire center stack. I got the car back and all appears in good order. However, I do have a slight "clicking" noise coming from the centre part of the dash or windshield. I don't know if it's just paranoia or what but i'll wait until my windshield settles and see if the noise persists. The dealership admitted that this has been a problem in the 2004 TSX but the 05 appears to have ironed this problem out.
Thats all.....
PS On a side note, I think I can be added to the list of people experiencing door rattle problems. I havent heard anyone actually describe the noise from the door but mine sounds like the window is somehow shifting and causing a noise regardless if it's open or closed. I'll keep an eye on that and update on that as well
Ashyne is offline   Reply With Quote
Old 01-30-2005, 04:30 PM   #73 (permalink)
(9)
larchmont's Avatar
I also suddenly had a rattle in the center part of the dash area after I had this work done (about a year ago) -- more specifically, it was from the immediate area of the CD/cassette.
It went away after about a week. At the time I thought it was probably just because the weather got warmer (the rattles in general have seemed to be worst and most prevalent in cold weather), but since it didn't come back this winter, perhaps it was that it just took a few days for the new installation to "settle in," as you suggest. (In my case it wouldn't have been the windshield that settled in, because I didn't have anything done on it; it would have been the new CD/radio unit.)
Old 05-20-2005, 03:34 AM   #74 (permalink)
Owner May2003
dlai is neutral and has a clean balanced record.
What next?
Same Problem with centre console lights (non-nav system).
All lights gone out on clock, audio system and air conditioning unit.
(dealer said it's all one piece)
Holding Aux/CD buttons doesn't fix problem.
Dealer will Replace Under Warranty
is the anything else I should be looking at getting replaced before the warranty runs out?
dlai is offline   Reply With Quote
Old 05-20-2005, 02:28 PM   #75 (permalink)
(9)
larchmont's Avatar
Not if nothing else seems wrong, which I imagine it doesn't.
Good luck with this fix. Judging from other people's recent experience, it should go well!
