Old 05-12-2007, 08:23 PM   #61 (permalink)
Staff: Rank 1
Administrator
Technical & Staff Operations
Peregrine's Avatar
My Ride: '04 TSX - SSM
Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.Peregrine is a priceless value of the forum, and commands true dignified respect.
yes, we already have that in our DIY Menu, Worsty
Peregrine is offline   Reply With Quote
Old 05-17-2007, 11:06 PM   #62 (permalink)
Captain of Cool
My Ride: acura/tsx/2004
Project_TSX can only hope to improve, or face mass condemn.
just curious when the warrenty runs out. i just got my 04 tsx last week.
04 TSX SSM 6MT
Project_TSX is offline   Reply With Quote
Old 06-04-2007, 12:03 PM   #63 (permalink)
TOTM 2006
crix868's Avatar
My Ride: Acura/TSX/2005
crix868 has a spectacular aura and a relevant respect from many.crix868 has a spectacular aura and a relevant respect from many.crix868 has a spectacular aura and a relevant respect from many.
So How Bout Acura Wont Warrantee My Lights B/c They Said It Seems It Has Been Tampered With, I Explained To Them It Is Oem Headlights Although They Are The Jdm Lights And Came Straight From Germany From Honda, The Service Advisor Assumed That I Opened Up The Lights Myself And Removed The Amber Reflector. Now He's Telling Me I Have To Contact Honda An Discuss It With Them Because He Cannot Warrantee It. What Should I Do At This Point?
December 2006 TSX of The Month -
97 Integra 4DR - JDM H22 Modified and Tuned, 355whp - 322tq - On Spray
05 TSX MR/Ebony 6-Speed - Back to Basics and a new Project coming soon....
Photo Sharing and Video Hosting at Photobucket
crix868 is offline   Reply With Quote
Old 06-04-2007, 02:15 PM   #64 (permalink)
Staff: Rank 1
Administrator
Peregrine's Avatar
go to another dealer
Old 06-04-2007, 06:25 PM   #65 (permalink)
Staff: Rank 5
Moderator
General
My Ride: CL9 2004 SSM
otesrepsaj is on the distinguished road to high status recognition.otesrepsaj is on the distinguished road to high status recognition.otesrepsaj is on the distinguished road to high status recognition.otesrepsaj is on the distinguished road to high status recognition.otesrepsaj is on the distinguished road to high status recognition.otesrepsaj is on the distinguished road to high status recognition.otesrepsaj is on the distinguished road to high status recognition.
honestly, all they do is insert two cheap metal clips on the top of the headlight to tighten the edges better so if you even bake your headlights a couple of times each the silicone glue will probably seal even tighter and you wont get any condensation going forward
i got clear corners from a UK spec accord and did the baking mod (thanks Pete). after the install and re-seal i've been through a couple of high powered car washes and a few major thunderstorms and have had no issues with condensation.
otesrepsaj is offline   Reply With Quote
Old 06-04-2007, 06:55 PM   #66 (permalink)
Staff: Rank 1
Administrator
Peregrine's Avatar
yeah, I think it all depends on how hard the hood is pressing on the headlights. The harder it presses, the more the housings separate. I baked and resealed perfectly several sets of headlights and all but mine did get some leaks sooner or later. Even in my headlights you can see how the housings are separated at the top, but luckily the moisture/water doesn't go in yet. But I have to get those clips ASAP.
Old 07-22-2007, 03:21 PM   #67 (permalink)
My Ride: ACURA TSX 2004
maddmax005 is neutral and has a clean balanced record.
condensation problems with headlights were a issue on earlier production models ...............2004 ,2005 and may extend to 2006 TSX'S..............
ACURA HAS FINALLY ADMITTED THE PROBLEM ( only tool 18 billion complaints)............
owner's of " affected " vehicles should have already rec'd a memo ( letter) in the mail advising owners of the issue.............
-ACURA will replace headlights as required .......................this is a extended " campaign bulletin".........................
- if you didn't get a letter........probably does not affect your vehicle , and the headlights have been re-designed.....................
maddmax005 is offline   Reply With Quote
Old 07-22-2007, 03:28 PM   #68 (permalink)
** MENTAL NOTE ***
IF you did get a letter about the headlights on your car , AND there is no current problem with them....(condensation)............DO NOT have the dealer replace them !!!
-if you zip down to the dealer and have the headlights replaced , like the letter tells you to do, then the warranty on the " new" and " modified" replacement lights is only as good as whatever the factory warranty was ! ( usually crap)
-i.e. the remainder balance of your current warranty ...........................
Old 07-22-2007, 03:30 PM   #69 (permalink)
keep the letter in a safe place , only get the headlights replaced WHEN there actually is a condensation problem................
that way , in 2 years when your headlights fog up , you got ACURA by the balls legally...............
hope this helps.........................
Old 07-22-2007, 04:50 PM   #70 (permalink)
Staff: Rank 1
Administrator
Peregrine's Avatar
yeah, this topic has already been thoroughly covered, madmax.
Just as FYI, about a month or 2 ago I picked up the set of clips from the dealer without going through their service dept. That set of brackets is like $3. Totally not worth the waste of time to leave the car for service. It's an easy fix if you just follow the TSB. Unless you have mositure in the headlights. In which case you may want them replaced.
Old 08-09-2007, 10:50 AM   #71 (permalink)
SToCK
AcidLotus's Avatar
My Ride: 2005 Acura TSX
AcidLotus has a spectacular aura and a relevant respect from many.AcidLotus has a spectacular aura and a relevant respect from many.AcidLotus has a spectacular aura and a relevant respect from many.AcidLotus has a spectacular aura and a relevant respect from many.
I drove through some major rain on the way to the mountains the other day, then noticed moisture condensation in the passenger headlight. I remember seeing this thread around so I searched and found. I'll print out the TSB and take it in for service here within the next couple of weeks. Thanks!
AcidLotus is offline   Reply With Quote
Old 09-10-2007, 12:09 AM   #72 (permalink)
bonifide hustla'
__nighthawk tsx's Avatar
My Ride: acura/tsx/2005
__nighthawk tsx is an unknown soldier, or on the road to either parallels.
yah i have the driver side headlight with condensation too...oh well might as well do an angeleye mod
05 nighthawk black pearl tsx
Injen SP CAI w/ MR Technology
2 10"JL Audio w6's w/ JL 500/1 amp
__nighthawk tsx is offline   Reply With Quote
Old 10-05-2007, 06:34 AM   #73 (permalink)
My Ride: Acura/TSX/2004
StevolutionTSX is an unknown soldier, or on the road to either parallels.
condensation in passenger side housing
I guess i'm not the only one experiencing any kind of condensation within the headlights. So I bought my '04 tsx used at a non-acura dealership about a month ago...i'm covered for 36k miles and the dealership agreed to look over the problem and fix it. I've got about another week before my appointment and it may take a couple days after that to get my headlight problem fixed if they have to order a new housing. Is there any way to fix the condensation problem temporarily until then? The sight of heavy condensation build up on one side and the effect it has on my horizon line with the lights on really bugs the crap outta me. Sorry, but when you upgrade from a civic si hatchback to an acura tsx you're definitely expecting nothing but the best. PLEASE HELP GUYS!
StevolutionTSX is offline   Reply With Quote
Old 10-10-2007, 11:01 PM   #74 (permalink)
My Ride: 04 TSX
chokin is neutral and has a clean balanced record.
hi guys, im From MN. and i got a 04 TSX yesterday from a private seller, and it has mositure in my driver side headlight. and the car has 63k miles , so i think it s outta warranty, anyways, i didnt get any letter cuz i bought the car from a private party. and anyone here From MN have to same peoblem. also since no warranty, will they still replace it for me??
chokin is offline   Reply With Quote
Old 10-10-2007, 11:46 PM   #75 (permalink)
Platinum Club Member
pizzaman555's Avatar
My Ride: acura tsx 2005
pizzaman555 is either technically knowledgeable, or well loved.pizzaman555 is either technically knowledgeable, or well loved.pizzaman555 is either technically knowledgeable, or well loved.pizzaman555 is either technically knowledgeable, or well loved.pizzaman555 is either technically knowledgeable, or well loved.pizzaman555 is either technically knowledgeable, or well loved.
I think you should still be coverd if not you can buy the clips they use to fix the problem for only a couple bucks.
pizzaman555 is offline   Reply With Quote
