Old 11-02-2009, 08:28 AM   #1 (permalink)
You Boost i-Vtec
JDmTypeS's Avatar
My Ride: 03 Accord Type S / Grey
JDmTypeS is an unknown soldier, or on the road to either parallels.
Service question
ok so i have 55k on the clock car has had nothing but oil changes...
What should i check and change/replace if needed?
just picked this car up not long ago so previous owner has done nothing,
Thanks,
Tom
03 Accord Type S (K24A3) 190Bhp
JDmTypeS is offline   Reply With Quote
Old 11-02-2009, 11:28 AM   #2 (permalink)
KBH
My Ride: TSX 2004
KBH is an unknown soldier, or on the road to either parallels.
Owner's manual is a good place to start to answer these questions. Transmission and brake fluid probably need to be changed. Air and cabin filters. Check your brake pad/rotor condition. Make sure all instrument cluster bulbs are functioning. If steering is an issue, have the fluid level checked. How are your tires?
KBH is offline   Reply With Quote
Old 11-02-2009, 02:38 PM   #3 (permalink)
USMC
newapocalypse's Avatar
My Ride: TSX / 2004 / Gray
newapocalypse , with enough acceptance, will soon become famous.newapocalypse , with enough acceptance, will soon become famous.
2004-08 TSX Service Manual Scans - DIY
newapocalypse is online now   Reply With Quote
Old 11-02-2009, 02:56 PM   #4 (permalink)
My Ride: s2000/ap1/spa yellow
f22b-dohc is an unknown soldier, or on the road to either parallels.
any of you know how to reset an annoying "service passed due" light?
i cannot reset the fuggging thing and the manual is not in the car.
i've tried it the same way i do my s2000
ign off, hold reset, turn to ign 2
ps. i've tried using the steering wheel controls too
f22b-dohc is offline   Reply With Quote
Old 11-02-2009, 03:44 PM   #5 (permalink)
You Boost i-Vtec
JDmTypeS's Avatar
Thankyou very much... i know my stuff i've had a EM2 that i worked hard at with cams and the like, so i know this sounds nooby but its a big step up for me in terms of engine power and complexicity, and at the end of the day i wanna do things right and make this thing last without any problems when i come to boost
So thanks for the input guys.
My tyres are good well apart from one which was previously under inflated so the sides have worn will be replacing soon
Do these cars use oil when driven hard?
