Old 11-02-2009, 02:15 PM   #1 (permalink)
My Ride: Acura/TSX/2004
jcbebechulo , with enough acceptance, will soon become famous.jcbebechulo , with enough acceptance, will soon become famous.
2 issues - please help
Hello everyone,
I am having an issue with the trunk. I have done some searches but don't seem to find what I'm looking for. My trunk will pop open from the lever(next to driver seat), but it won't work with my keyfob. i called Acura, and they want me to bring it in. I don't have a warranty anymore, so I just wanted to know if there are a couple of things that it might be.
Thanks,
"Some People Say Cucumbers Taste Better Pickled"
jcbebechulo is offline   Reply With Quote
Old 11-02-2009, 02:25 PM   #2 (permalink)
iVTEC no koe
HoRRo's Avatar
My Ride: Acura/TSX/2005
1. Did you check the locking switch (for the trunk) that is inside your glove box?
2. Does your outside trunk button (on the exterior of the trunk) work (when all doors are unlocked)?
Reference threads:
Should be a post from me telling you how to test the trunk release actuator in one of these.
Help with faulty trunk button
trunk button
My car is stock, I promise.
Old 11-02-2009, 03:16 PM   #3 (permalink)
I checked the button inside the glove box.
i havent checked the exterior button when all the doors are locked. What exactly should i be checking?
Old 11-02-2009, 03:23 PM   #4 (permalink)
The links talk about the switch assembly, but the trunk opens fine, its just not opening with the keyfob.
Old 11-02-2009, 03:36 PM   #5 (permalink)
My Ride: 2004 TSX
a2dadamm is neutral and has a clean balanced record.
my fob is a little screwy as well. I opend it up and blew out the dust put it back it works now bt i have to really press firmly on the button. press hard on the button and see if it works.
a2dadamm is offline   Reply With Quote
Old 11-02-2009, 04:35 PM   #6 (permalink)
iVTEC no koe
HoRRo's Avatar
For what it's worth, my trunk button (on the keyfob) always required me to press and hold for about 1-3 secs. Since day one.
Old 11-02-2009, 04:36 PM   #7 (permalink)
iVTEC no koe
HoRRo's Avatar
There is a button above the license plate that is an electronic switch to open the trunk. See if it works....
Old 11-02-2009, 04:39 PM   #8 (permalink)
iVTEC no koe
HoRRo's Avatar
The trunk opens with 2 mechanisms:
1. Manual/mechanical trunk release. The lever which your gas door is also setup on.
2. Electronic/Actuator. Same logic as your door lock knob. It has both manual (via key) and power door lock (actuator) to unlock. Your trunk uses a similar setup to release via the keyfob or the exterior trunk button.
Those links refer to the exterior trunk switch/button. The electronic aspect (#2).
Old 11-04-2009, 01:03 PM   #9 (permalink)
ok, so i tried a couple of things.
I found the button in the glove box, it was set to off. I set it to 'ON'. when I have the trunk open, and I press the keyfob button, it makes a sound like it works. But when it is closed, it doesn't do anything. The button that is by my license plate doesn't do anything as well.
Old 11-04-2009, 04:42 PM   #10 (permalink)
I LUV JDM
tsx4life's Avatar
My Ride: CL9 2006
tsx4life is either reputation whoring, or truly reaching the elite club.tsx4life is either reputation whoring, or truly reaching the elite club.tsx4life is either reputation whoring, or truly reaching the elite club.tsx4life is either reputation whoring, or truly reaching the elite club.tsx4life is either reputation whoring, or truly reaching the elite club.tsx4life is either reputation whoring, or truly reaching the elite club.tsx4life is either reputation whoring, or truly reaching the elite club.tsx4life is either reputation whoring, or truly reaching the elite club.
wassup jean... same problem here my key fob works and latch inside car works...but the button outside the trunk dont... taking my car in to the dealer.....
" I Love JDM "
tsx4life is online now   Reply With Quote
Old 11-05-2009, 03:38 PM   #11 (permalink)
Who doesn't love a Honda!
TPhong's Avatar
My Ride: '05 SSM Acura TSX/'00 GPW S2000 AP1
TPhong , with enough acceptance, will soon become famous.TPhong , with enough acceptance, will soon become famous.TPhong , with enough acceptance, will soon become famous.
Make sure your Driver front door lock actuator is actually locking. If it doesn't lock, neither will the trunk. I had to take mine to the dealership, and the only thing they said, was that "someone" removed the kickpanel and didn't put it back in properly. I told him BS, but screw it, it's fixed.
TPhong is offline   Reply With Quote
Old 11-06-2009, 11:16 AM   #12 (permalink)
wassup Rob, let me know what the dealership tells you.
i tried locking the latch on the side of the driver seat and it locks. so that isn't the issue.
Old 11-10-2009, 08:30 PM   #13 (permalink)
I LUV JDM
tsx4life's Avatar
My Ride: CL9 2006
jean...actually my button was off...lol...im a loser for two years i thought my latch was broken... check to see if the dealer can fix it for u as a valued customer....?
" I Love JDM "
