Originally Posted by griffojm
Sounds like the heater core might be shot. Hopefully its not the dreaded A/C failure.
Just to check, your engine temp. does rise, right? And, do you have enough coolant in the reservoir and radiator?
the temp it does rise from cold to warm like below half if that what you mean ...or u mean when i turn the heater on .... i'll recheck my fluids ... because i had a lil issue with the car overheated before due to an apparent dirty fuse
