Go Back   TSXClub.com Forums > Performance > Suspension / Chassis > 1st Gen - Suspension, ...
Old 09-28-2005, 04:10 AM   #16 (permalink)
604TSX's Avatar
My Ride: 04 TSX
604TSX is neutral and has a clean balanced record.
awsome write up!!! =)
should do more of these posts haha ^^
learn so much =)
thx noel
604TSX is offline   Reply With Quote
Old 02-02-2007, 03:26 AM   #17 (permalink)
My Ride: 06 TSX
Billy is neutral and has a clean balanced record.
here is a newb question for the pros.
I am planning on installing some Eibach Prokits. What kind of struts should I get that would work the best with them? I still want the good ride quality. any suggestions?
Billy is offline   Reply With Quote
Old 02-02-2007, 03:35 AM   #18 (permalink)
My Ride: 06 TSX
also, do I need a camber kit? what does it do?
Old 02-04-2007, 09:13 PM   #19 (permalink)
Staff: Rank 1
Administrator
General Operations
TOTM 2004
Plenty of choices in terms of struts, I'm sure others will chime in with relevance. While the camber kit will correct the aggressive negative camber introduced on the rear wheels because of the height reduction. The correction of negative camber will introduce a more balanced tyre contact patch/wear area for tyre longevity/increased mileage for road use.
Old 03-31-2007, 10:56 PM   #20 (permalink)
kennungesser's Avatar
My Ride: 2000 Dodge Dakota 4.7 4x4 v8
kennungesser , with enough acceptance, will soon become famous.kennungesser , with enough acceptance, will soon become famous.kennungesser , with enough acceptance, will soon become famous.
I'm getting ready to install the Tien Basics next Saturday. And I have two questions.
1: Did I lie to my wife when I said "the ride is not going to be THAT much different than stock, just a little firmer." ? I'm only going to lower it about 1.5 f/ 1.9 rear. Maybe a little more. On 18s in the summer, stock 17s in the winter.
2: Do I have to rent a spring compressor?
Thanks guys,
Ken
kennungesser is offline   Reply With Quote
Old 08-17-2007, 02:51 AM   #21 (permalink)
Let me...help you!
SoCaliTrojan's Avatar
SoCaliTrojan is either technically knowledgeable, or well loved.SoCaliTrojan is either technically knowledgeable, or well loved.SoCaliTrojan is either technically knowledgeable, or well loved.SoCaliTrojan is either technically knowledgeable, or well loved.SoCaliTrojan is either technically knowledgeable, or well loved.SoCaliTrojan is either technically knowledgeable, or well loved.
Thanks guys,
Ken
1. I have Tein SS, and I think Tein basic are equivalent to the Tein SS setting of 8 (from 1 to 16). On some roads, my tein feels smoother than stock...on other roads, you can tell. Firmer is the right word (as opposed to rough or hard). If ride quality is important to your wife, you might want to get Tein SS or tein flex w/ EDFC. That way, you can soften up the ride for her when she rides with you. But for the most part, everyone who has gotten Tein basics have had no complaints about the ride quality. Right now my Tein's are set to 14 in front and 12 in back...so it's pretty stiff. It had been previously set to 1 (full soft) for my parents. It did take a couple of days to get used to it, but now I don't even notice the ride that much. I'm sure with Tein basic's, your wife probably won't complain unless she's a nitpicker or has a sensitive butt.
2. For Tein SS, some OEM parts have to be removed so that they can be re-used on the Tein's. I don't know if the basics have that issue. If so, you might want to rent a spring compressor (unless you're Mr. Heeltoe aka Marcus...in that case, he can do it without a spring compressor).
SoCaliTrojan is offline   Reply With Quote
Old 10-17-2007, 12:39 PM   #22 (permalink)
My Ride: HONDA CIVIC 2005
EP3FAMILY is an unknown soldier, or on the road to either parallels.
Smile
First off really great article, you break down the differances so that any one could understand.
EP3FAMILY is offline   Reply With Quote
Old 05-17-2009, 03:24 PM   #23 (permalink)
My Ride: 2004/tsx/white
Vtecfrog is an unknown soldier, or on the road to either parallels.
My idea of a perfect setup involves a linear spring combined with a helper spring. This setup is used on certain coiliovers, in order to provide some relief from road imperfections while using a stiffer spring.
The helper spring is designed to be routinely fully compressed and becomes fully compressed as soon as the supension is loaded significantly.
The big advantage of a helper spring is a consistent spring rate under load and in some cases it also helps preload the main spring providing better predictability during mid-corner bumps.
Just my two cents from a typical "internet forum expert" with no credentials and week-end track champ (in my own mind anyway).
cheers eh!
Vtecfrog is offline   Reply With Quote
