10-29-2009, 04:40 PM
#1 (permalink)
C.R.E.A.M.
Car Pulls to the Right
What could cause my car to pull to the right when the steering wheel is centered?
I took my car in for an alignment because of this issue and everything looks fine as far as specs go. Unfortunately, the car still pulls to the right. I'm kind of suspecting that the alignment was done without straightening the steering wheel. I suspect the toe to be off by the same amount on both front wheels. Tire pressure is all consistent and there are no bends or dents on my wheels.
What else could cause this to happen?
Mods, pls move this thread to the "Wheels & Alignment" section.
10-29-2009, 04:48 PM
#2 (permalink)
 Regional Meet Leader DC Metro
The machine might be off, sensors weren't reading correctly, the steering wheel might not have been centered, or the mechanic didn't do it right. All possible options
10-29-2009, 04:54 PM
#3 (permalink)
C.R.E.A.M.
I've pretty much narrowed it to what you just said. I'm just wondering if there could be any other likely causes.
10-29-2009, 05:00 PM
#4 (permalink)
back at it
When my mom was looking for a TL we found one that had an issue with pulling to the right. We had the dealership do an alignment and it still didn't help. We ended up passing up that car and never did find out the issue. Hopefully you can figure out what's wrong with your car.
Have you curbed it recently or done anything that could have knocked the alignment off? The TL had a nasty curb rash on the front right wheel so I suspected that more than the rim and alignment was screwed up when it got curbed.
10-29-2009, 05:02 PM
#5 (permalink)
C.R.E.A.M.
^ no curbing or damage. just normal daily driving. bumps and small potholes here and there, but nothing insane. the toe does look visually off when i park the car but that might just be me and my imagination.
10-29-2009, 05:04 PM
#6 (permalink)
back at it
Did they not give you a print out of the alignment specs after they finished?
10-29-2009, 05:06 PM
#7 (permalink)
C.R.E.A.M.
they did and everything looked good. i am no alignment expert but i know what specs i like and should be. the only thing that leaves me with is that the steering wheel wasn't straight for the entire alignment.
10-29-2009, 05:11 PM
#8 (permalink)
I tell you exactly what it is, Radial pull. Sometimes the weave in the tire breaks up or wasn't made properly and will cause the car to pull to a specific side. Try and cross rotate your tires even if they are directional and see if anything changes.
I have had the same issues since I got my Dunlop Direzza Z1 Star Spec. I had the car aligned 3 time after the initial alignment with Specs that were perfect(1 time at the dealer, the rest at other high end shops). Still had the pull, said **** it as long as it's the tires I'm cool. Later I found a set of wheels with tires that I had always wanted, the tires were some low quality brand.....no pull what so ever, even after I rotated. Sold the wheels months later, put the stocks with the Dunlops back on, slight pull to the right.
You can try everything you are thinking but I can guarantee 100% that it's the tires. Allot of people even on s2ki.com have had this issue with various brands.
There is a good thread on Acura Zine about this with lots more information. I posted my findings there with a couple of other people from that forum.
10-29-2009, 05:13 PM
#9 (permalink)
back at it
Hm that's interesting. Makes sense too.
10-29-2009, 08:14 PM
#10 (permalink)
My Ride: 07' CGP/Ebony 5AT
i second the radial pull. i had the same prob. alignment was perfect, tire pressure correct; everything indicated that the car should drive straight.
the dealer's shop foreman also test drove my car and he said the radial pull is common for some reason... after rotating the tires, the pull went away.
35% tint, 5% visor tint, 5% moonroof tint - M3 style deck spoiler - CT Engineering Icebox - LED lights everywhere
10-29-2009, 08:25 PM
#11 (permalink)
Start crossing tires and see if the pull follows
10-29-2009, 09:02 PM
#12 (permalink)
My Ride: TSX / 2006 / Red
Yes, it is usually tire related when everything is in spec. Something as simple as air pressure differences can push/pull you in one direction or the other.
Ever watch auto racing? Indy? Nascar? You'll hear them talk about adjusting air pressures. Part of the air pressure adjustments help the vehicle turn better.
Think I'm crazy? Put 30 psi in your left-side tires and 50 psi in the right-side ones (assuming that your tires can take that, check the sidewalls first for maximum pressure,) and drive around a bit. Then swap the air pressures - do 50 left, 30 right.
Don't forget to reset to recommended pressures after fun-time is over!
'06 TSX, auto, red
'07 Fit, sport, auto, red
'89 CRX, 5-sp, mainly white, 300k+ miles
10-30-2009, 01:32 AM
#13 (permalink)
C.R.E.A.M.
Thanks for all the feedback guys. I'll probably put on the stocks on to see if it is radial pull. If worst comes to worst, i'm going to just say f*ck it and jsut drive it seeing how only the tires will take the beating.
annoying thing is, the steering wheel has that slight pressure to go back to the center position so i have to constantly pull it slightly to the left or counterclockwise.
10-30-2009, 02:05 AM
#14 (permalink)
SOCSARGEN
My Ride: 05 tsx msm,08 zx6r
+1 had the same issue after i got new tires and alignment done on my gf civic..car just keeps pulling right so shop said its radial pull they swap the tire on the right like 3 times until the pulling was gone...so it could just be the bad tire..
2005 tsx meteor silver 6 speed w/ navi.
engine-hondata,mr injen intake,karcept tbs,nuspeed bar,carbon fiber radiator panel
suspension-tein ss,progress rsb,ingall camber kit,
exterior- euro r front lip,a-spec side/rear,password jdm foglights,jdmtoy led license light,drag dr-34 18x8 47et,michelin ps2 235/40/18,apr fr. carbon fiber splitter,egr roof spoiler
interior-strutking pedal,jdmtoy led lights,
ride # 2>> 08 zx6r mods.
motowerkz gp exhaust
motowerkz undertail kit
xenon hid 50w 8k H and L
xenon t10 led center light
waiting to come..
egr roof spoiler
10-30-2009, 04:12 AM
#15 (permalink)
My Ride: honda/tsx/07/CGP
just try to rotate the front to back and back to front tires, I had that kind of experience. Then bought new tires and it when away.
| Thread Tools |
| Display Modes |
Linear Mode
