Go Back   TSXClub.com Forums > Performance > Suspension / Chassis > 1st Gen - Suspension, ...
Old 11-05-2009, 12:04 AM   #1 (permalink)
My Ride: Acura TSX 2007
losothefatso can only hope to improve, or face mass condemn.
Sway Bar Problem?
Since it's getting really cold in Seattle here, I've been hearing a extremely loud squeak sound from my rear whenever I go up even a small bump at so low speeds. I was told I need to grease between the bar and the bushings?
How should I go upon this? I was wondering if I should buy new greaseable bushings to save me time in the long run.
losothefatso is offline   Reply With Quote
Old 11-05-2009, 12:15 AM   #2 (permalink)
My Ride: 04 acura tsx
speedlimitz , with enough acceptance, will soon become famous.speedlimitz , with enough acceptance, will soon become famous.
Had the same problem and I used brake lube ( same stuff you lube up the slide pins on calipers). Actually took the bushings off and smeared it on the bushing where the bar sits, haven't had the problem in over a year.
speedlimitz is offline   Reply With Quote
Old 11-05-2009, 12:15 AM   #3 (permalink)
RML-R1
Regional Meet Leader
DC Metro
pdpgps's Avatar
My Ride: TSX/2005/CGP
pdpgps is either technically knowledgeable, or well loved.pdpgps is either technically knowledgeable, or well loved.pdpgps is either technically knowledgeable, or well loved.pdpgps is either technically knowledgeable, or well loved.pdpgps is either technically knowledgeable, or well loved.pdpgps is either technically knowledgeable, or well loved.
yeah its the sway bar. I had that problem too. You can add more grease to the bushings, or get these polyeurathane bushings from heeltoe that supposedly eliminate the sqeaking noise. I bought them and the noise went away.
pdpgps is offline   Reply With Quote
Old 11-05-2009, 12:33 AM   #4 (permalink)
Yeah, I was recommended those poly bushings as well, how much did they cost from Heeltoe? Man I wonder how the hell I'm doing this without a lift. I know I'll have to take off the rubber crap thats on there now, and regrease between the bar and the bushing correct?
Hope WD-40 works.
Old 11-05-2009, 01:10 AM   #5 (permalink)
Age
X1000r/min
Age's Avatar
My Ride: 2007 TSX MT
Age is either technically knowledgeable, or well loved.Age is either technically knowledgeable, or well loved.Age is either technically knowledgeable, or well loved.Age is either technically knowledgeable, or well loved.Age is either technically knowledgeable, or well loved.Age is either technically knowledgeable, or well loved.
Hope WD-40 works.
IMO better to use lithium grease than WD-40.
Veni, Vedi, Abeo
Age is offline   Reply With Quote
Old 11-05-2009, 01:14 AM   #6 (permalink)
I'll look into Lithium grease, but do you guys think polyurethane bushings are a good investment? I'm guessing they would cost me around $23 Dollars shipped.
Old 11-05-2009, 01:43 AM   #7 (permalink)
Retired
TOTM 2009
wong05tsx's Avatar
My Ride: Acura/TSX/2005
wong05tsx is either reputation whoring, or truly reaching the elite club.wong05tsx is either reputation whoring, or truly reaching the elite club.wong05tsx is either reputation whoring, or truly reaching the elite club.wong05tsx is either reputation whoring, or truly reaching the elite club.wong05tsx is either reputation whoring, or truly reaching the elite club.wong05tsx is either reputation whoring, or truly reaching the elite club.wong05tsx is either reputation whoring, or truly reaching the elite club.wong05tsx is either reputation whoring, or truly reaching the elite club.wong05tsx is either reputation whoring, or truly reaching the elite club.wong05tsx is either reputation whoring, or truly reaching the elite club.
You could just try the grease first... its only ~2$ for a large can..
parting out! http://tsxclub.com/forums/tsx-classi...-part-out.html
2005 CGP AT w/ Navi
Audio | Hertz HSK165 Components | Hertz HCX165 Coaxials | Sundown SAX 100.4 | Sundown SAZ 1500D | Two - 10" SSA Icon D1 | Mercman's Harness & Balun | Dynamat Xtreme | Dice R4 w/ Text | Optima YT D35
Suspension | Progress Rear Sway | Neuspeed Strut | Buddy Club RSD Coilovers | Ingalls Rear Camber kit | Works VS-XX Hypersilver 18x7.5 +45 // 18x8+50 | Falken FK452 | Bridgestone RE960 | MOOG Endlinks | Hawk HPS | Brembo Blanks w/ X-Drill & Slotted |
Aero/Cosmetics | | Mugen Grill | JDM Hoodtrim | 20% Tints all around | Work Extended Blue Lugs | Mugen Emblem | Euro-R Front // A-spec Rear + Side Underspoilers| Window Trim DIY Blackout | Mugen Visors | Rear window spoiler | Painted IM Cover | Yakima Ski Rack |
Lighting | 05 FishDM Headlights | EDM Taillights w/ Foglights | 4300K HID Fogs | Polarg 6000k LED 194 Corners| PIAA 7440 Mirror Orange Turns
Performance | Hondata Reflash | NST Pulleys | Modded Comptech Icebox | Comptech Header | 06 Cat/Exhaust| TB Bypass
To come... | Refinish wheel lips & Powdercoat bronze
Bay area detailin holler at me!
wong05tsx is online now   Reply With Quote
Old 11-05-2009, 01:46 AM   #8 (permalink)
Wong haven't heard from u in a while! Where can I get my hands on this "magical grease for $2,"
Old 11-05-2009, 04:50 AM   #9 (permalink)
Age
X1000r/min
Age's Avatar
Try Home Depot.
Veni, Vedi, Abeo
Old 11-06-2009, 07:53 PM   #10 (permalink)
Retired
TOTM 2009
wong05tsx's Avatar
I got mine from Autozone. Home depot would most likely have it too..
2005 CGP AT w/ Navi
Old 11-06-2009, 09:26 PM   #11 (permalink)
My Ride: Tsx/2006/Mag Gray/6MT
gene112601 is neutral and has a clean balanced record.
WD-40 will fix that problem.
gene112601 is online now   Reply With Quote
Old 11-07-2009, 08:54 AM   #12 (permalink)
My Ride: 04 tsx blue
harmonichonda , with enough acceptance, will soon become famous.harmonichonda , with enough acceptance, will soon become famous.
i'd go silicone first, sprays can be had cheap enough. Work great silencing suspension noises
harmonichonda is offline   Reply With Quote
Old 11-07-2009, 05:49 PM   #13 (permalink)
My Ride: 2004 TSX
Black Ninja is an unknown soldier, or on the road to either parallels.
I use the silicone spray I got from Acura...I spray it on whenever I notice any squeaking.
Black Ninja is offline   Reply With Quote
Old 11-11-2009, 12:28 AM   #14 (permalink)
My Ride: TSX/05/ABP
evenq is an unknown soldier, or on the road to either parallels.
Another option is to clean the bar and bushings well than wrap bar in the area the bushings are with Teflon tape. I haven't had any squeaking for over a year already. Any kind of grease or lube may attract dirt and other contaminates to the bushing and may cause them to wear out quicker.
evenq is offline   Reply With Quote
