Go Back   TSXClub.com Forums > Performance > Suspension / Chassis > 1st Gen - Suspension, ...
Old 11-05-2009, 02:39 AM   #1 (permalink)
Superhammatime
My Ride: 2004 Acura TSX Silver / 2004 Pontiac Vibe
D-BesT is neutral and has a clean balanced record.
Brakes == Weak
Am I the only one to feel that the TSX stock brakes are weak?
I've had them serviced a few weeks ago, and the mechanic says my brakes are still good.. Yet they feel weak compared to my Pontiac Vibe :S (which has 2 discs, and 2 drums)..
They;ve always felt weak on the car, am I the only one that feels that way?
Maybe it;s time for a big brake kit and cross drilled / slotted rotors!!!
2004 Acura TSX / 2004 Pontiac Vibe - "The VIBERATOR"
D-BesT is offline   Reply With Quote
Old 11-05-2009, 04:34 AM   #2 (permalink)
My Ride: pwp rsx-s
Eros168 is an unknown soldier, or on the road to either parallels.
i feel the same way as well compared to my rsx-s, prob upgrade rotors and pads will help.
Eros168 is offline   Reply With Quote
Old 11-05-2009, 05:04 AM   #3 (permalink)
RSMark5's Avatar
My Ride: VW GTI MKV RS
RSMark5 is an unknown soldier, or on the road to either parallels.
When you had your brakes service did they test the fluid? I know in my buddys 08, the brakes definatly don't feel weak.
On the subject of brakes, many upgrades can be made to stock brakes before the need of doing major upgrades. Big cross drilled and slotted rotars may look really cool but will mostly decrease performance and cost a fortune. They decrease the pad surface area, increase pad wear, there is less material to disappate heat, as wel as being natrually prone to cracking. Drilling is done to reduce unsprung weight. Race teams and high dollar brakes of course aren't simply drilling blank rotars, they are casting them that way. Doing it this way apparently has a whole host of benifits.
For the street, and light track use, use a high quality and agressive pad. Upgrade your fluid, and do some stainless steel lines. I'm sure that it will work wonders. Maybe that will help you get the stopping distances and pedal feel your looking for. Also as a last resort maybe you could borrow some OEM parts from another acura with larger brakes.
Car: 2006 VW GTI 2.0T DSG Pk2 Reflex silver, Anthracite Leather.
Exterior: Euro fog grills, flat black grill Black sidemarkers, Black mirror signals, Blacked Out badges, shaved rear, Höen 9006 xennon match fogs, and FTP bulbs.
Interior: Osir O-pod, Osir dry silver CF trim, Newsouth 52mm boost gauge, Eurocubby, Euro passat light switch and mirror adjuster, JL 10w1v2, Kicker75.2, C.A.S. fiberglass enclosure.
Performance:APR S2 software, APR DP, BSH PCV, Revison "D" piston DV, NGK plugs.
Suspension: SPAX 28way full adjustable coilovers, BSH 27mm solid RSB, Hawk HPS, Tyrol caliper bushing kit, ATE
Not Installed yet: Before Christmas: Mason-tech/koni adjustable air struts, Airhouse single billow rear airbag, twin Vivair 380s, Autopilot management with F-B-S-S control,Koni FSD rear shocks, Dieselgeek skidplate,Votex front lip, Votex base carrier bars, VW classic luggage rack, Yakima fairing.
RSMark5 is offline   Reply With Quote
Old 11-05-2009, 02:17 PM   #4 (permalink)
RML-R9
Regional Meet Leader
Vancouver
TOTM 2009
icemiko's Avatar
My Ride: TSX/2005/PWP
icemiko has a spectacular aura and a relevant respect from many.icemiko has a spectacular aura and a relevant respect from many.icemiko has a spectacular aura and a relevant respect from many.icemiko has a spectacular aura and a relevant respect from many.icemiko has a spectacular aura and a relevant respect from many.
The car is heavy that's why the stock brakes sucks, even though I have aftermarket rotors and pads, they seem weak too. Get a BBK if you want really good braking.
icemiko is offline   Reply With Quote
Old 11-05-2009, 03:09 PM   #5 (permalink)
My Ride: Acura TSX 2005
ying is neutral and has a clean balanced record.
i feel the same way too, i got Hawk HPS and flushed the fluid with Motul and still not as responsive as a standard 08 civic. Like in the civic, u just tap the brake and its grabs alot harder than mine.
ying is offline   Reply With Quote
Old 11-05-2009, 06:29 PM   #6 (permalink)
EuroRspec's Avatar
My Ride: S2000
I have stock brakes and the car stops good. I came from an s2000.
Exterior-Stock
Interior-Stock
Engine-Stock
Old 11-05-2009, 08:19 PM   #7 (permalink)
Evan
evan42781's Avatar
My Ride: Acura/TSX/2006
evan42781 , with enough acceptance, will soon become famous.evan42781 , with enough acceptance, will soon become famous.evan42781 , with enough acceptance, will soon become famous.
get some SS lines. There cheap and with give you stiffer feel.
06' Nighthawk Black Acura TSX
--15% Tints front and back
--Fog lights rewired
--HID Conversion Fogs 6000k
--6000k Headlights
--V1 mounted next to rear mirror
--Custom Made ICEBOX with K&N Filter
--Tanabe DF210 and Koni Yellows
--Progress Rear Sway Bar
--Ingalls Rear Camber Kit
--Painted Front Grill
--Smoked Tailights and Reflectors
--Red JDM Valve Cover
--Apexi Exhaust
--Buddy Club Racing Condenser
--JDM Replica Headlights
--Blacked out Window Trim and Handles
--White LED's throughout interior
--Drilled and slotted front rotors
--Hondata
--Spoon Replica Spoiler
--Powder-Coated 05 TSX rims
Mods to Hopefully Come
--Headers 4-2-1
--15mm Wheel Spacers
--Body Kit
evan42781 is offline   Reply With Quote
Old 11-05-2009, 08:40 PM   #8 (permalink)
Donating member
My Ride: 05, Auto
Yea, my Vibe had stronger feeling of brakes.
Old 11-06-2009, 12:41 PM   #9 (permalink)
Superhammatime
Thanks.. I don't think I'll be considering upgrading to cross drilled / slotted or even big brakes.
I'll be investing in new pads and maybe new rotors. heard good reviews about the EBC greens.. however, fast wear... I'll stay away from monroe LOL
Old 11-06-2009, 04:52 PM   #10 (permalink)
C.R.E.A.M.
tekneek's Avatar
My Ride: 06 ASM
tekneek has a spectacular aura and a relevant respect from many.tekneek has a spectacular aura and a relevant respect from many.tekneek has a spectacular aura and a relevant respect from many.tekneek has a spectacular aura and a relevant respect from many.tekneek has a spectacular aura and a relevant respect from many.
stock brakes work fine for me.
tekneek is offline   Reply With Quote
