10-19-2009, 08:15 PM
#1 (permalink)
Steering wheel vibration at 60 mph and up , help !!
Hey folks, my 2004 is driving me nuts lately because of the vibration on the steering wheel. It vibrates when i pass 60 mph, I tried wheel balance and alignment, none of them help, it can't be a bent rim, anyone have any idea whats the cause ? any help will be much appreciated, thx in advance !
10-19-2009, 09:29 PM
#2 (permalink)
I believe your having the same problem as other member . Do a search for wheel shaking
10-20-2009, 01:52 AM
#3 (permalink)
It can be a few things, axles, breaks, rims and ball joints.
10-20-2009, 02:28 AM
#4 (permalink)
My Ride: TSX/06/CGP-ITR/97/VSM
Check rotors...
Check tires for if they're flat-spotted or are just junk. The best way is to swap front wheels with the rear and so on, if the problem "moves", you have a pretty good idea that it's tire or wheel based.
Check ball joints...if it pops when you move from a stop and pops when you come to a complete stop, good chance those are bad (upper or lower).
Axles...very similar to ball joints, but a lower pitched thunk, and also audible during turns too.
Just a few thoughts...it's a process of elimination.
11-03-2009, 04:20 PM
#5 (permalink)
I saw another post simliar to this, they end up fixing the problem by changing the axles, will that help ??
11-03-2009, 08:40 PM
#6 (permalink)
If it's the axles, yes.
11-03-2009, 09:05 PM
#7 (permalink)
yeaaaaa............. still havent fixed mines. I'm about to make a Wheels shake @60mph" club
FS: Falken Torque 5's 19" FK452
- 20% tint - BlueBat Overlays - Painted Calipers - Russell SS Brake Lines - Hawk Ceramics Pads - Rotora Slotted F/R Rotors - iSimple - JDM Fog Lights
11-05-2009, 10:55 PM
#8 (permalink)
Check the wheel bearings. That's what vibrations usually mean.
11-06-2009, 02:21 PM
#9 (permalink)
 Regional Meet Leader Vancouver
That happened to my TSX when I 1st bought it too, I changed the rotors, pads and brake fluid and it's all good now.
11-06-2009, 04:05 PM
#10 (permalink)
C.R.E.A.M.
if you recently got rims, look into hubcentric rings
11-07-2009, 01:37 PM
#11 (permalink)
-Dose of TSXtacy-
Prob ball joints,tie rods or maybe even as other members said the axle.
JDM TSX. N.W.G SOCIAL GROUP
CALLING ALL MEMBERS THAT ARE SLAMMED ! PLEASE JOIN
11-07-2009, 03:16 PM
#12 (permalink)
I'm in the same boat right now. My next step is rotors and if that doesn't help a wheel swap and finally just change the axles.
11-07-2009, 09:24 PM
#13 (permalink)
HOLY shit YOUR ALIVE!?!?!! haha waddup man. idk if raul told you but i took it to paragon changed passenger side axles still got it. checked engine mounts they were good. bought new rotora slotted rotors hawk ceramic pads russell ss brake lines n bled the brake fluid with acura DOT3 and i still got the damn vibration @ 60.. by the way paragon also balanced the tire.
| Thread Tools |
| Display Modes |
Linear Mode
