Go Back   TSXClub.com Forums > Performance > Wheels & Alignment > 1st Gen - Wheels, ...
Old 10-29-2009, 04:15 PM   #1 (permalink)
C.R.E.A.M.
tekneek's Avatar
My Ride: 06 ASM
tekneek has a spectacular aura and a relevant respect from many.tekneek has a spectacular aura and a relevant respect from many.tekneek has a spectacular aura and a relevant respect from many.tekneek has a spectacular aura and a relevant respect from many.tekneek has a spectacular aura and a relevant respect from many.
Ingalls Camber Kit Locking Nut Loosening Issue
For those of you with the Ingalls rear camber kit, how do you loosen the locking nut that is closer to the middle of the car? I went in for an alignment and the tech said they had to unbolt the inner side of the camber bar in order to loosen the locking nut on that side. They loosened the locking nut on the outer end using a wrench, but a wrench can't get into the inner locking nut.
Worst comes to worst, i'm going to unbolt the inner side of the camber kit arm from the car and loosen the locking nut before i take it in for an alignment.
Is there an easier way?
tekneek is offline   Reply With Quote
Old 10-29-2009, 04:30 PM   #2 (permalink)
My Ride: acura/tsx/2004
luder917 is neutral and has a clean balanced record.
thats what i had to do with mine. i couldnt get a wrench to fit in there to hold the nut. but it wasnt very time consuming to take out that extra bold.
18*8+30 225 40 18 (now with 15mm spacer in the rear)
are you sure they dont fit???
http://www.tsxclub.com/forums/showth...316#post400316
+22 coming soon...
luder917 is offline   Reply With Quote
Old 10-29-2009, 05:08 PM   #3 (permalink)
C.R.E.A.M.
tekneek's Avatar
My Ride: 06 ASM
thanks for the response. i'm surprised this isn't something that is more talked about seeing how a lot of us on here have the ingalls kit.
Old 10-29-2009, 05:26 PM   #4 (permalink)
EuroRspec's Avatar
My Ride: S2000
There is a notch on the tube after the nut on both sides, if you loosen the nut on the opposite side where you can reach the nut and twist the tube, the other side will loosen to finger tight. After that get the specs where you want them tighten the nut you can't reach with your finger so that it touches the tube, then turn the tube into the nut locking them both into place. Then just tighten the nut you can reach and you're done.
Exterior-Stock
Interior-Stock
Engine-Stock
Old 10-29-2009, 07:21 PM   #5 (permalink)
Forum Vendor
Forum Vendor
MrHeeltoe's Avatar
My Ride: 90 Integra
MrHeeltoe has a spectacular aura and a relevant respect from many.MrHeeltoe has a spectacular aura and a relevant respect from many.MrHeeltoe has a spectacular aura and a relevant respect from many.MrHeeltoe has a spectacular aura and a relevant respect from many.
I don't seem to have a problem tightening and loosening the nuts when the kits are installed.
You should have the same amount of threads on both sides of the arm, right?
HeeltoeAuto.com, ACURA SPECIALIST
Enter Coupon Code tsxrocks for 5% off!
DO NOT PM!
MESSAGE ME HERE
EXCLUSIVE ACURA Parts
1G TSX
2G TSX
Get your driving socks here
Swtichblade Keys : ATLP Distributor : TEINS : Racingbrake Rotors
Parts Broker Extraordinaire! Matching you up with the right parts at the right price!
Click here for all our sales, specials, promotions and group buys!
http://tsxclub.com/forums/heeltoe-automotive/
MrHeeltoe is offline   Reply With Quote
Old 10-29-2009, 07:38 PM   #6 (permalink)
Staff: Rank 6
Petty Moderator
Performance
endlesswinterco's Avatar
My Ride: 06 ABP AT
endlesswinterco is on the distinguished road to high status recognition.endlesswinterco is on the distinguished road to high status recognition.endlesswinterco is on the distinguished road to high status recognition.endlesswinterco is on the distinguished road to high status recognition.endlesswinterco is on the distinguished road to high status recognition.endlesswinterco is on the distinguished road to high status recognition.endlesswinterco is on the distinguished road to high status recognition.
yea, never have had the problem with my kit. must have changed specs about 6 times now without a problem.
endlesswinterco is offline   Reply With Quote
Old 10-29-2009, 11:27 PM   #7 (permalink)
EuroRspec's Avatar
My Ride: S2000
That's how I did it.
Exterior-Stock
Interior-Stock
Engine-Stock
Old 10-30-2009, 01:27 AM   #8 (permalink)
C.R.E.A.M.
tekneek's Avatar
My Ride: 06 ASM
one side is super easy because there is nothing in the way of a tool. the side that is closest to the middle of the car is harder because the locking nut is surrounded. so do you guys just hand loosen and hand tighten the locking nut?
EuroRspec, I'll have to give your way a try. I was actually thinking about it because if you spin the rod it should loosen the locking nut I can't get to with a tool.
When i first put it on and got an alignment, the locking nut wasn't that hard to loosen with yoru hands. I'm thinking some dirt or something got into the threads and maybe its stuck. I'll have to give it a closer look.
Old 10-30-2009, 03:37 PM   #9 (permalink)
porkchop
matiasneto's Avatar
My Ride: Acura TSX 06
matiasneto has a spectacular aura and a relevant respect from many.matiasneto has a spectacular aura and a relevant respect from many.matiasneto has a spectacular aura and a relevant respect from many.matiasneto has a spectacular aura and a relevant respect from many.
mine are rusted locked
\06 tsx CGP\
matiasneto is offline   Reply With Quote
Old 10-30-2009, 08:14 PM   #10 (permalink)
pally777's Avatar
My Ride: TSX/2008/Pearl White 5sp Auto /w Navi
pally777 is neutral and has a clean balanced record.
I'm planning on installing my camber kit next year, but I've heard people painting them prior to installing to prevent rust issues. Did any of you do that? If so, what over the counter stuff can you buy to paint it? Maybe it'll prevent this issue of not being able to loosen a lock nut?
pally777 is online now   Reply With Quote
Old 10-30-2009, 10:31 PM   #11 (permalink)
EuroRspec's Avatar
My Ride: S2000
I would use some grease rather than paint
Exterior-Stock
Interior-Stock
Engine-Stock
