03-29-2009, 05:59 AM
#1 (permalink)
Forum Vendor
Progress rear sway bars for CU2, in stock and shipping NOW
Suspension - 2009- Acura TSX & JDM Honda Accord CU2 - Acura Parts - HeelToe Automotive
Progress anti-roll bars dramatically improve handling. How? They minimize the traction-robbing body "lean" that rolls part of the outside tires off the pavement. Progress Sport-tuned Anti-roll bars from HEELTOEAUTO.com replace skinny OEM bars and rubber bushings with larger diameter (stiffer) alloy steel bars and polyurethane bushings. More roll stiffness means less body "lean", and the tires stay flatter on the pavement (larger contact patches). The result is more grip and added driver control!
-Less body roll means more traction, faster cornering speeds, and increased driver confidence.
-Polyurethane bushings produce crisp response on turn-in.
Progress Anti-roll bars are cold-formed in-house using our custom-built precision bending equipment. Both laser-cut and CNC bar ends are MIG welded in place using a precise fixture for an exact fit.
SEE MY VENDOR FORUM FOR FULL POST AND MORE PICS!
04-09-2009, 08:42 PM
#2 (permalink)
My Ride: TSX Tech Package/2009/Vortex Blue
quick question. Doesnt the car already have sway bars? What is the plus to adding an aftermarket one such as this
04-09-2009, 08:54 PM
#3 (permalink)
Yes they do have OEM sway bars.
Plus is this is larger to reduce body roll
February 2009 TOTM The Sleeper!
The Only Easy Day Was Yesterday"
SoCal folks need parts installed? Hit me up!!
04-10-2009, 11:54 AM
#4 (permalink)
Forum Vendor
Anti-sway bars go by many names. Sometimes they are referred to as anti-roll bars, roll bars, or sway bars...but they all do the same exact thing: tie the left and right suspension together so that the car corners flatter.
The sway bar is basically a spring that mounts to the left and right suspension somewhere, then is secured to a solid part of the chassis. It works like a torsion bar, by twisting. Naturally, a larger bar is going to be harder to twist so it is desirable to upgrade the sway bar from stock size to improve handling.
Why only the rear??????
The rear sway bar is the most commonly upgraded suspension part in a front-wheel drive car, after shocks and springs. The rear sway bar helps make up for FF cars' tendency to push, or understeer, into corners. Upgrading the rear sway bar noticeably improves handling on the TSX without compromising ride quality. This part is easily the most Bang for the Buck you are going to get out of your TSX suspension...at least it was on the 1g TSX...and just about any other Honda we've worked on for that matter.
04-10-2009, 12:57 PM
#5 (permalink)
yeah I was surprised to see that the tsx came with factory strut bar and sway bar, although it's not as strong, it's still better than nothing (that my old cars had)
2006 TSX/6MT/Aspec/Navi
04-11-2009, 12:52 PM
#6 (permalink)
Forum Vendor
Yes more cars are coming with strut braces now. But Sway bars are very common. It would be more weird for a car not to come with them really now-a-days.
04-13-2009, 10:18 PM
#7 (permalink)
thanks! ill probly be ordering one soon
05-27-2009, 08:18 PM
#8 (permalink)
My Ride: TSX/2009/Black/6 speed
lawls i just bought a car cover and rear bumper aplique from you too expensive jeesh, lololol but i need the cover bad cause i'm getting tired of washign my car everyday cause of the sap lololol
In response to the voice on your navi...
Originally Posted by i2ide
how about a ghetto person?? lol. go straight fo fo miles, turn left at da liqua sto, go a lil furtha, take a right into the gas station and ......................ax somebody beee!tch. ahahahaha
haha, I had to take it lolololololol
| Thread Tools |
| Display Modes |
Linear Mode
