Go Back   TSXClub.com Forums > Performance > Suspension / Chassis > 2nd Gen - Suspension, ...
Old 10-14-2009, 03:29 PM   #1 (permalink)
Darren's Avatar
My Ride: 2009 Acura TSX
Darren , with enough acceptance, will soon become famous.Darren , with enough acceptance, will soon become famous.Darren , with enough acceptance, will soon become famous.
Putting an end to the rumors. Questions WILL be answered!
Marcus from HeelToe Automotive and I have teamed up to put an end to the rumors and finally confirm whether or not the front brakes on the CU2 are the same as that of the 1st Gen. TSX, beyond just the rotors.
Within the next week or so, I will be test fitting the 1st Gen. TSX Rotora 4-POT 13" front big brake kit on my CU2 to verify if it is a direct bolt-on or not. Manufacturers have stated that everything is the same between the two generations, but we have yet to see a 2nd Gen. with a BBK installed to actually confirm this. So hopefully their statements hold true and the upcoming install goes smoothly.
Before I decided to just jump into this, I did a little bit of research of my own. I went to my local Acura dealer and was able to get the parts manager to print me off the brake diagrams and part numbers from both the 2008 1st Gen. TSX and the 2009 2nd Gen. TSX:
2008 1st Gen. TSX: http://farm3.static.flickr.com/2594/...85cb0152_b.jpg
2009 2nd Gen. TSX: http://farm3.static.flickr.com/2489/...fab3a39b_b.jpg
Comparing the 2 diagrams and part numbers, you'll see that based on numbers 7 & 8 from both diagrams, which is the right and left front caliper assemblies, the part numbers from both generations are exactly the same. The rotors on both generations are also both 11.8". The part numbers for the rotors are different, however the parts manager proceeded to tell me that the rotors shown on the 2008 diagram are discontinued and replaced with the ones shown on the 2009 diagram. Lastly, I was allowed into the shop to look over a 1st Gen. that was up on a lift that had just had new wheel bearings installed, and upon close inspection, the entire brake assembly seemed to be an exact match to the 2nd Gen. So given this information, I'm pretty comfortable stating that I believe they are indeed identical and the big brake kit will be a direct and easy bolt-on.
I will be updating this thread with my findings and will post detailed pictures from the install. Assuming the kit bolts up just fine, I'm sure my 19" RonJons will clear the calipers, but for those interested, I'll also test fit the kit to see if the stock 17" wheels clear the brakes as well.
So hopefully all goes well and we'll be able to add a few more aftermarket parts to our CU2's currently short list. I thank Marcus at HeelToe for helping to make this happen as his help and services have been top notch.
Stay tuned!
'09 CBP TSX Premium AT
Aero Sport Kit, Paintmatched Front Grill, Rear Decklid Spoiler, 19"x8" Liquid Silver RonJon Legends, 245/35 Falken FK-452, Rotora Front Big Brake Kit, Eibach Pro-Kit, Project KICs R26 Black Chrome Lugs, 35% Tint, Debadged Rear, Removed Intake Resonator
Darren is offline   Reply With Quote
Old 10-14-2009, 03:46 PM   #2 (permalink)
Metal Head
1TSXer's Avatar
Hmmm, interesting. Let us know how it all works out.
04 CGP 6spd MT
Old 10-14-2009, 04:07 PM   #3 (permalink)
My Ride: TSX/2009/Glacier Blue
Jeremiah , with enough acceptance, will soon become famous.Jeremiah , with enough acceptance, will soon become famous.
I look forward to this information.
I would like to have an LSD, hopefully that can be put on the list of parts to test in the near future. I would, but the cost of shop rental to test the parts, and then it maybe not fitting is not in my budget to buy both the part, and the shop time, for a part that may not fit.
Jeremiah is offline   Reply With Quote
Old 10-17-2009, 01:36 AM   #4 (permalink)
My Ride: TSX Tech Package/2009/Vortex Blue
VortexBlueTSX is an unknown soldier, or on the road to either parallels.
Hopefully it works, cant wait to find out
VortexBlueTSX is offline   Reply With Quote
Old 10-23-2009, 10:14 AM   #5 (permalink)
Darren's Avatar
Just a cell phone pic for now. Installing them tonight!
Old 10-23-2009, 10:18 AM   #6 (permalink)
Boost Enthusiast
audioserf's Avatar
My Ride: Boosted 04 6MT
What width/offset are your RJ's?
OEM wheels on a 1st gen don't clear the Rotoras. I mean, they DO, but with a half millimeter of clearance... I wouldn't feel safe driving with the setup.
Good luck.
Old 10-23-2009, 12:01 PM   #7 (permalink)
Darren's Avatar
Good luck.
My RJ's are +48 and will clear the caliper no problem.
The stock 2nd gen wheels are 17" +55.
Old 10-23-2009, 12:07 PM   #8 (permalink)
Boost Enthusiast
audioserf's Avatar
Yeah RJ's are good to go. 17x7 +55 is the same size as 1G stockers. I think you'll find it's an uncomfortably close fit with the BBK!
Old 10-23-2009, 12:47 PM   #9 (permalink)
Darren's Avatar
It probably will be, but for the sake of this experiment I'm going to test it out for those that may be interested to know. Plus I told Marcus I would.
Old 10-23-2009, 01:09 PM   #10 (permalink)
Staff: Rank 6
Petty Moderator
Performance
endlesswinterco's Avatar
My Ride: 06 ABP AT
endlesswinterco is on the distinguished road to high status recognition.endlesswinterco is on the distinguished road to high status recognition.endlesswinterco is on the distinguished road to high status recognition.endlesswinterco is on the distinguished road to high status recognition.endlesswinterco is on the distinguished road to high status recognition.endlesswinterco is on the distinguished road to high status recognition.endlesswinterco is on the distinguished road to high status recognition.
this will deff be interesting, can't wait to see pics of the fitment!
endlesswinterco is offline   Reply With Quote
Old 10-25-2009, 12:12 AM   #11 (permalink)
Darren's Avatar
Well everybody, I'm happy to report that it was a complete success! Installed the kit last night and everything lined up and bolted up without any modifications or fitment issues. Even the brake lines which became a concern ended up fitting perfectly without a problem. The only issue we ended up having was removing the aligment screws on the stock rotor to get them off. We got 3 of the 4 of, but then the last one dedided to completely strip, so we had to use a screw exctractor to get it out. I'll be replacing all for of them with new ones though, hopefully they have stainless steel ones available because the stock ones rusted and being exposed to all that heat were locked in there pretty good. So that being said, it is confirmed that the 1st gen BBK's (at least the Rotora kit) are 100% compatible with the 2nd gen. However you will need aftermarket wheels with at least a +48 offset.
I didn't even bother to test fit the stock wheels because you'll soon see why in the pics below. This became my biggest concern after the install, I literally have 1mm clearance with my 19" RonJon Legends. There's no rubbing, but I'll be getting some 5mm spacers for peace of mind and to extend the gap a bit. We were shocked how close I ended up being to the wheels not fitting. A different wheel with the same offset might have more clearance or may not fit depending on design, but with spacers, an 18" or greater will certainly work.
So enough talk, onto what everyone wants to see, the pics...
Everything bolted up and mounted without any issues.
The incredibly close wheel clearance!
You might also notice my new Project KICs R26 Black Chrome lug nuts. I love 'em!
Old 10-25-2009, 12:38 AM   #12 (permalink)
i2ide's Avatar
My Ride: Acura TSX/2004/ CGP
ballin.
good for you man.
you can officially say you're the first person with a BBK on a second gen.
'04 TSX l 5AT l CGP
CLICK HERE!
Old 10-25-2009, 03:46 AM   #13 (permalink)
Donating member
My Ride: 05, Auto
this is a great news!
Old 10-25-2009, 10:05 AM   #14 (permalink)
Tishkevich's Avatar
My Ride: TSX/2009/Black/6 speed
Tishkevich is neutral and has a clean balanced record.
Well first person to share :-P
In response to the voice on your navi...
Originally Posted by i2ide View Post
how about a ghetto person?? lol. go straight fo fo miles, turn left at da liqua sto, go a lil furtha, take a right into the gas station and ......................ax somebody beee!tch. ahahahaha
haha, I had to take it lolololololol
Tishkevich is offline   Reply With Quote
Old 10-25-2009, 10:06 AM   #15 (permalink)
Tishkevich's Avatar
some mean ass lug nuts imo
