Originally Posted by speedlimitz
Might be blow by from worn piston rings, internal coolant leak, PVC valve
is there any way to clean it out should i try seafoam or just remove what i can do an oil change and keep an eye on it.
I was thinking of having the head gasket done just because the car has a shit load miles on it and se if they will hot tank the head and do a valve adjustment as well.
